AC unit won't turn on
I installed a window type 18000 BTU air conditioner that runs on 220v. I also installed the 220 outlet. The outlet has power, according to the current meter the power cord to the unit has power and power is making it into the unit, but it won't turn on. I have tried both a 15 amp and 30 amp breaker but neither helps. The unit is rated for 15 amps. Help! I am so frustrated!!
CONTROLLER IS NOT WORKING BUT AC BLOWER IS DIRECTLY STARTED BUT COMPRESSOR NOT STARTED
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioning Tamarac
Apr 11, 2016 | LG Window Ac Unit 18000 Btu, Energy Star...
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
My ac keeps turning on and off by itself
1) Test the main switch, can be shorted, or defective contact you must replaced .see the diagram attached. God bless you
May 14, 2012 | LG Window Ac Unit 18000 Btu, Energy Star...
AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Jul 05, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
For a/c unit, is there an adapter available or do I need a new plug cord
Actually you should buy and install an AC wall outlet. An AC uses more amperage than most any other appliance due to the fact it has 2 motors the compressor and the blower / fan motor. An AC wall plug has larger terminals so that the plug does not ever heat. Changing the cord to a different and smaller terminal plug is a bad choice due to the danger of overheating the wall outlet terminals. You can buy the AC horizontal terminal outlets at any hardware store. Unless you have a 110V AC unit you will also have to run a 220V #10 Romex (3 wire) with ground to the outlet to be in code.. An AC unit 1 HP (10,000) BTU or larger requires over 15 Amps for start up. Those that are 20,000 BTU or larger obviously require more than 15 amps as a power source.
Thanks for using FixYa.
Kelly
Jun 01, 2010 | Heating & Cooling
We just bought a frigidaire 22000 btu unit. We we
If you have or know someone how has a multi meter just test that you have 220 volts at the outlet. Thats about the only way to tell. The fan will run if you only have 120v at the outlet, just not the compressor. so it will not cool. If you only 120v at the outlet it could be just a fuse or breaker problem. If it's a new outlet then it could be wiring wrong also.
Hope this help
Dan
May 22, 2010 | Frigidaire Heating & Cooling
What type of outlet do I use ?
It depends....
Some units are 120 volt and others are 220v
Units up to about 18,000 btu are usually 120 and over that they are often 220...
The pug for the 120 will look like a normal light cord plug and the 220 plug will have the two blades going sideways instead of up and down...
Also for the larger units you will need a dedicated circuit for them as they take too much power to run on a circuit with anything else...
heatman101
Apr 28, 2010 | Heating & Cooling
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
