Question about Intel Computers & Internet
When i tryed to upgrade my windows 98 to 2000 Although during the final steps of the setup the computer resarted and it stared over again then again and again?
  • Jorge Maldonado Jul 20, 2009
    But I can't go back to Windows 98
  • 44 Answers
This is due to either incompatible BIOS settings or incompatible hardware. Make sure all of your hardware is compatible with Windows 2000 before upgrading. If so, then check all BIOS settings to ensure compatibility.
Posted on Jul 20, 2009
  • HeathG Jul 23, 2009
    I never told you to go back to Windows 98. I said to check settings in BIOS,and do a little research on your own to make sure your hardware is compatible. You are on the internet now, so obviously you have access.
    Try the install of Windows 2000 again. Sometimes glitches happen and it just has to be done again to work.
How can I fix windows 10 installation error c1900101?
  • Disable (preferably uninstall) your Antivirus utility before attempting the upgrade.
  • Restart a few times and try again.
  • Disable General USB Devices (example - Smart Card Reader).
  • If you are using a SCSI hard disk, make sure you have drivers available for your storage device on a thumb drive and it is connected. During Windows 10 setup, click the Custom Advanced Option and use the Load Driver command to load the appropriate driver for the SCSI drive. If this does not work and setup still fails, consider switching to a IDE based hard disk.
  • Do a clean boot and try again.
  • If you are upgrading using the .ISO file, disconnect from the Internet during setup, if you are connected by LAN (Ethernet) or Wi-Fi, disable both and attempt setup again.
  • If you are updating through Windows Update, when the download reaches 100% disconnect from the Internet LAN (Ethernet) or Wi-Fi and proceed with the installation.
  • If that does not work, try using the .ISO file to upgrade if possible.
  • If you are connected to a domain, switch to a local account
  • If you have any external devices attached to the machine, disconnect them (example, gaming controllers, USB keys, external hard disc, printers, non-essential devices). If you are installing Windows 10 using Windows Update, try the following:
    1. Press Windows Key + X on the keyboard and then select "Command Prompt (Admin)" from the menu.
    2. Stop the BITS, Cryptographic, MSI Installer and the Windows Update Services. To do this, type the following commands at a command prompt. Press the "ENTER" key after you type each command.
    net stop wuauserv
    net stop cryptSvc
    net stop bits
    net stop msiserver
    3. Now rename the SoftwareDistribution and Catroot2 folder. You can do this by typing the following commands in the Command Prompt. Press the "ENTER" key after you type each command.
    ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
    ren C:\Windows\System32\catroot2 Catroot2.old
    4. Now, let's restart the BITS, Cryptographic, MSI Installer and the Windows Update Services. Typethe following commands in the Command Prompt for this. Press the ENTER key after you type each command.
    net start wuauserv
    net start cryptSvc
    net start bits
    net start msiserver
    5. Type Exit in the Command Prompt to close it and then restart the computer.
May 14, 2018 | Computers & Internet
Wen i turn my laptop on it keeps stared a windows xp setup upgrade an keeps asking 4 my *********** but its not on my bottom off my laptop no more an dont no it and i can not get in my laptop now
look on line for a windows p code, it must be an upgrade key and , almost certainly, specifically intended ofr your laptop's make. what is the make and model please? If there is a recovery partition on your laptop ?? that might allow you to recover the original setup. lternatively, if there is data that you MUST have, obtain a 2.5 to 3.5 drive adapter and attach the hdd to a desktop as a secondary drive, when in windows on your desktop machine you will h=ba able to access the data on the laptop drive.
Jun 08, 2016 | Microsoft Windows XP Professional
Ve an Asus K510J With Pre Installed Vista And I need to Clean Install Windows 7 On it Which is Not Proceeding and Says Files Missing
Sounds like you need to stick with Vista. Believe me, Windows 7 is just a tab bit better, but you'll have problems with it.
Apr 27, 2012 | Computers & Internet
I have a gateway gx7022e windows xp computer. When i try to boot it up the white letters pop up then the screen goes to the gateway screen and freezes. Then my num lock comes on but my keyboard wont work....
At power on / power up, look for the key during the bootup (black screen with white text), that allows you to enter SETUP. If none designated such as F1, F2 F10 etc, then quickly click the delete button a few times and that may get you into setup. You may have to turn off the computer if you miss that window of time if it rfequires pressing the delete button a few times. Keep an eye out for the Enter Setup key though. To turn off the computer press and hold the power button 'till is shuts down and resart the process until you get to the setup screen in bios. In setup bios environment, look for set factory defaults and then save and restart. That may solve the issue of the lockup.
Jan 10, 2011 | Gateway GX7022E (RBGX7022E) PC Desktop
Cannot install unto windows 7
Instructions to be followed in order to install Windows 7:
STEP 1. Put the Windows 7 disc into your DVD drive, and then start your computer.
STEP 2. Click Install now.
STEP 3. Click an option whether to get important updates for installation.
STEP 4. choose the edition you want to install, and then click Next to continue.
STEP 5. Click the I accept the license terms check box, and then click Next to continue.
STEP 6. Click the type of installation you want: Upgrade or Custom.
STEP 7. Wait while Setup copies and installs Windows 7 on your computer. Your computer might restart several times during this process.
STEP 8. Next you need to enter few details such as, country, time, and keyboard, user accounts, product key activation, time-zone, date, and time and etc.
STEP 9. Wait while Setup configures Windows 7 prepares your desktop.
Nov 16, 2010 | Computers & Internet
I'm not able to open any of the applications on Win7 OS. Everytime I try to open any applications it asks me to save it. Could you please what is the problem and how can it be resolved?
Is you Windows 7 pre-installed with the computer? If not, please insert the Windows 7 disk, and try to run "Repair Install".
1. Start Windows 7, and log on to an administrator account.
2. Disable any 3rd party firewall, antivirus, or other security program to avoid it from possibly preventing the repair upgrade installation of Windows 7.
3. Place your Windows 7 installation DVD into the DVD drive, while still in Windows 7 (Step 1), and click on the Run setup.exe option in the AutoPlay window from within the currently installed Windows 7. (See screenshot below)
NOTE: If the AutoPlay window does not open, then open the drive folder in Computer and run the setup.exe file.
4. If prompted by UAC, then click on Yes.
5. Click on the Install Now button to start the installation. (See screenshot below)
6. Uncheck the I want to help make Windows installation better box (unless you would like to ), and click on the Go online to get the latest updates for installation option. (See screenshot below)
7. Windows 7 will now check online for and install any available installation updates. (See screenshots below)
8. Check the I accept the license terms box and click on Next. (See screenshot below)
9. Click on the Upgrade option. (See screenshot below)
10. The installation of Windows 7 will now begin. (See screenshot below)
NOTE: During the installation process, your screen may flash and computer will restart a few times.
11. After the final restart, you will see this screen for a moment. (See screenshot below)
12. Type in your Windows 7 product key number. (See screenshot below step 13)
13. Uncheck the Automatically activate Windows when I'm online box unchecked, then click on the Next button. (See screenshot below)
NOTE: You can activate Windows 7 later after you make sure it is running properly. (See step 20 below)
If you chose to automatically activate Windows online when you set up your computer, automatic activation begins trying to activate your copy of Windows three days after you log on for the first time.
14. Click on Use recommended settings. (See screenshot below)
15. Select your time zone and set your time and date settings, then click on the Next button. (See screenshot below)
16. Click on the option for your computer's location to select the correct network location type settings to be applied for that location. (See screenshot below)
NOTE: It is best to select Public location for the best security.
17. Windows 7 will now prepare your desktop to startup. (See screenshots below)
18. Check to see if you are missing any user files. If you are, then you can copy them from the C:\Windows.old or the hidden protected operating system C:\$INPLACE.~TR and C:\WINDOWS.~Q backup folders. (See screenshot below)
19. If everythig checks out in step 18, then you can run Disk Cleanup (step 6 at this link). You will need to click on the Clean up system files button first, and then check the Files discarded by Windows upgrade, Previous Windows installations, and Windows upgrade log files boxes. (See screenshot below)
NOTE: This will delete the C:\Windows.old, C:\$INPLACE.~TR and C:\WINDOWS.~Q folders from step 18 above.
20. Refresh your Windows Experience Index (WEI) score.
21. When done, all you will need to do is to activate Windows 7, and make sure that your security programs are enabled again.
Jul 15, 2010 | Dell Computers & Internet
My windows xp campaq laptop will not recognize the logitec 9000 webcam software.
Try to install first the driver of the cam which is in your cd/dvd driver. during the setup process, there's a step that ask you to connect the hardware which is a cam and then plug the cam and continue setup, after finishing installation, restart the computer then that's the time your cam recognized, then continue little remaining setup to finally complete the installation.
Mar 22, 2010 | Logitech Webcam
Upgrading firmware
Downloading the Firmware Step 1: Before downloading the firmware, make sure that your computer has an active Internet connection. If your computer is plugged directly into the router and cannot get online, disconnect your router and plug your computer directly into your cable or DSL modem. Step 2: Once you are able to get online, click here to go to the WRT54G Version 5 Download page. Step 3: Click Download to download the firmware file. Approx. file size (Zip file): 1.39 MB If you are using Windows XP Service Pack 2 (SP2) and Internet Explorer, you may see a 'Pop-up blocked' message in your browser Information Bar. If so, click the bar and select Temporarily Allow Pop-ups. Then, click the Download link again. Step 4: Click Save in the File Download dialog box that appears. Step 5: In the Save As dialog box, choose a location for the file (like the Desktop) and click Save. The wrt54gv5_fw_1[1].00.6_US_code.zip file will then be downloaded. When the download is complete, click Close if prompted. Step 6: Double-click on the wrt54gv5_fw_1[1].00.6_US_code.zip file and extract its contents to a single folder (or to the Desktop). NOTE: You will need to use a utility to open and extract files from the ZIP file archive. Popular software to use is WinZip®. For information on how to download WinZip®, visit the following website: http://www.winzip.com. You can also use the built-in unzipping features of Windows XP to unzip the contents from the archive. The following (3) files should be available: * wrt54gv5_fw_1.00.6_US_code.bin * Readme.txt * wrt54gv5_ver.txt Upgrading the Router's Firmware Step 1: Plug your computer directly into Port 1 on the back of the router. Step 2: Make sure that the router's power is plugged in. Step 3: Open Internet Explorer. Type http://192.168.1.1 into the Address Bar and press [Enter]. Step 4: You will be prompted to enter a username and a password. Leave the username field blank, and enter admin for the password. Then, press [Enter] or click OK. NOTE: If you are asked for the password again, the router's default password was changed. Try a common password that you might have changed it to. If are still unable to log in, hold in the Reset button on the back of the router for 30 seconds. After 30 seconds, unplug the power to the router and then plug it back in. Then, try Steps 3 and 4 again. Step 5: When the router's web-based Setup page loads, click on the Administration tab. Step 6: On the Administration page, click on the Firmware Upgrade sub-tab. Step 7: On the Firmware Upgrade page, click Browse. Browse to the location where the firmware files were extracted, and select the wrt54gv5_fw_1.00.6_US_code file. When the file is selected, click Open. Step 8: Click the Upgrade button on the Firmware Upgrade page to start the upgrade. The upgrade will take a few minutes - please do not unplug the router's power cord or make any changes during this process. Step 9: When the upgrade has completed, the following message will appear: "Upgrade is successful. rebooting...." Completing the Firmware Upgrade Step 1: Close Internet Explorer. Step 2: Hold in the Reset button on the back of the router for 30 seconds. After 30 seconds, unplug the power to the router and then plug it back in. This step will ensure that the new firmware loads properly! When you are finished... The firmware upgrade is now complete! You can now use the router's Setup Wizard CD to configure your Internet service and set up your wireless connections.
Feb 16, 2006 | Linksys (WRT54GC) Router
Computers & Internet Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
