When recording with a Sony HVR-HD1000u camera, projecting through a IN42 projector, the image being captured mirrors and I would like to know how to correct this problem...
  • Tom Davis Jul 20, 2009
    I just offered someone $50 if they could get this problem resolved for me. If this solution works, I am willing to send you the balance of the offer ($35).
    I am going to accept your answer to my problem, but what do I do if it does not work?
    I'm not sure if the solution works yet. When Igo in to the church tomorrow to check it out, I will let you know. Your reply sounds convincing.
    I will be glad to give you high ratings if this works!
    Tom
  • 336 Answers
Since your projector is HDTV compatible, I suggest you use an HDMI cable to connect your camcorder. Please note: Your camcorder is PAL system, so you need to set the video in format of your TV/LCD to PAL system.
Regards,
Jeep Brainy
Posted on Jul 23, 2009
  • 2,200 Answers
Hi
You need to get into the menu on your projector to correct this. The usual steps are -
Access the OSD menu, select Image Control , select Flip Image , and then select Horizontal, Vertical , or Both until the image is displayed correctly.
These problems occur when the input on the projector associated with your camera has been set up for rear screen or ceiling mount operation.
This should resolve the issue. Please remember to rate my answer. Many Thanks.
Posted on Jul 20, 2009
  • Radio Code Pro
    Radio Code Pro Jul 21, 2009
    Hi Tom,
    I hope my fix sorted out your problem for you but in case there is any confusion for you when you enter the menu of your projector I wanted to leave this additional comment for you. I have already emailed customer support to pass this comment on to you as I could not get back into the thread after it had closed. However I have just discovered a way to do this and so wanted to leave the comment here for you as well.
    Your particular model of projector uses a different language for performing this procedure in its menu and I wanted you to have this information in case there was any confusion for you when you open the menu. The exact method for your particular projector is as follows;
    When you go into the Menu go to Settings - select System Menu - then check or uncheck the box as necessary relating to R (which stands for rear). This will correct the image that is projected.
    As you can see the language on your projector is quite different so I wanted to clarify that for you.
    Thank you also for your kind offer to forward the balance of your $50 ! You are very kind. I would be quite happy that you donate that amount to the charity of your choice should you choose to do so.
    I hope your problem is now sorted and thank you for using FixYa
    Kind Regards
    RixsFixes.
How to fix Sony HVR-HD1000U camcorder if it is not charging
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
Dec 01, 2015 | Sony HVR-HD1000U Camcorder
Why is my sony hvr hd camcoder not switching on
hi,
Tape door on my sony HVR-HD1000 will not go down
hi,
the tape deck mechanism is faulty, the remedy is to change the mechanism. if you can repair it open take out the mechanism, remove the head, eject housing,and the sensors mechanism locking plate etc, then peel out the flexible cable from the mechanism, and change it.
Nov 18, 2015 | Sony HVR-HD1000U Camcorder
How to transfer video to computer
Your owners manual will show you on page 74 how to connect the iLink cable between the camera and computer. If you have lost the manual, it is downloadable for free.
Sep 02, 2013 | Sony HVR-HD1000U Camcorder
HVR-HD1000E, The tape is locked-check the tab
hello, i think the tape tab is jammed if you will need help to: Disassembly,Repair, Maintenance or adjustments and more you can download the factory service manual from the below link:
http://goo.gl/ubSnD
Good Luck
May 01, 2013 | Sony HVR-HD1000U Camcorder
Sony HDR fx7 fuzzy image
http://www.youtube.com/watch?v=KYHtCvyHhc4&feature=youtu.be
i have sony hdr fx7 . image are blur look like in the video . both indoor or outdoor . why? how can i fix it.
Nov 30, 2011 | Sony HDR-FX1000, HDR-FX7, HVR-HD1000U, and...
I have a sony hvr-hd1000u - I am getting an error message that says reinsert the cassette. Please let me know what you think the issue is. My camera will not work now because of this message. The cassette...
Hello.
This problem is solved by replacing the cassette complet mechanism, part number A1437006A MD (N220) SUB ASSY (S) A
... the cause: the flex is broken.
you can buy it on this website: https://www.servicesplus.sel.sony.com/sony-part-number-A1437006A.aspx
Hollmann.
serviciotecnico@videosistemas.com
Nov 27, 2010 | Sony HVR-HD1000U Camcorder
How to cleane comcoder head
You will need a cleaning cassette- the same type that you record on, but with a cleaning tape in it instead of recording tape.
Nov 02, 2010 | Sony HVR-HD1000U Camcorder
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
