Question about Ubi Soft Entertainment Petz: Horsez 2
Petz 4 won't run on my Windows Vista p.c.
I have Windows Vista 64 gbit. I have read that I can download and run the petz4.2 patch, and this will allow the game to run on my computer. I have tried this with no luck. Petz 4 will not even begin to run on my computer. Any suggestions?
  • 198 Answers
Right click the shortcut, select "Run as Administrator"
Have a good day.
Posted on Jul 20, 2009
I can not get my singer futura ce200 to work on windows 7 64 bit or where i can get the 2.5 upgrade patch from singwer futura suport .com have a patch but wont work in win 7 64 bit even though it says so...
As far as I can tell most computerized machines won't work with Vista or Windows 7 (64). The only solutions I have seen work is to either have your computer re-formated and partitioned and installed with a dual operating system.
Or...
Go buy a used machine that already has Windows XP
Aug 28, 2012 | Singer Sewing Machines
Is there a windows 7 driver for the A920
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell A920 All-In-One Inkjet Printer owners thread (W7)
Remember virus programs and firewalls will block communications.
Rick
Oct 19, 2011 | Dell A920 InkJet Printer
Cannot get a driver to load off line. 64 bit windows7 no disk
Dell 964 Photo All-In-One Printer owners thread (W7)
Rick
Aug 14, 2011 | Dell Photo 964 All-In-One InkJet Printer
I have a dell printer A920 and an acer computer with windows 7. Having trouble getting the printer to work
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block communications.
Rick
Apr 18, 2011 | Dell A920 InkJet Printer
New windows7 CPU 64 bit Cannot install software PaperPort Deluxe 7.02. Help
Checking their website, v7.02 does not support Windows 7. Their drivers page lists up to Windows Vista, which should also work on Windows 7, but the only mention of a 64-bit OS is the fact that WindowsXP-64 is NOT supported. You will probably need to either a) get in touch with Visioneer and find out whether there is a patch or update that will allow v7.02 to run on Win7-64, or b) upgrade to v11 (the latest version of Paperport). Hope this helps!
Mar 16, 2011 | Visioneer One Touch 7600 USB
How to download vista,and wat is the requirments need for vista
Please Dont install VISTA, it is bloated, slow and buggy.
Either stick with XP or use Windows 7, 7 is far better than Vista.
If you are after a free download, try this 1 http://isohunt.com/torrent_details/204960365/windows+7?tab=summary
, you will need a torrent client like Utorrent, this is here http://www.utorrent.com/downloads
The download will take a while, it will come with an activation patch.
You usually install windows 7 without the serial, then run the patch after to make it genuine.
Sep 08, 2010 | Microsoft Windows Vista Ultimate Edition
I download the drivers but when I go to install it says it cannot find them
Depending on the make and model of your computer and operating system, you'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until you're prompted to restart your computer.
Install the proper drivers. You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
If using Windows 7, install the Vista drivers in the compatibility mode. Vista 32-bit for Windows 7 32-bit and Vista 64-bit for Windows 7 64-bit.
Links to the patch/drivers and installing in the compatibility mode can be found at...
924 Photo All-In-One Printer owners thread (W7)
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
Dell AIO922 and Dell Inspirion with Vista 64bit
windows Vista 64 bit it is important to run the Vista patch that you can download from the Dell website (Downloads and drivers).
Run the patch, after removing the printer USB cable from the computer then Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to to do so
Hope this will fix the problem
Sep 23, 2009 | Dell 922 All-In-One InkJet Printer
Maxtor Mini 4 (250GB) is not supported on Vista Premium 64bit
microsoft tells it's 64 bit compatible:
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=Maxtor%20OneTouch%204%20Mini%20-%20hard%20drive%20-%20250%20GB%20-%20Hi-Speed%20USB&v=Maxtor&uid=&pf=0&pi=0&c=Storage%20Devices&sc=Hard%20Drives%2C%20External&os=32-bit
you have an USB issue
try to download all patches for your 64-bit windows from microsoft
Jun 25, 2009 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Ubi Soft Entertainment Petz: Horsez 2 Logo
885 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
