Question about D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
I just got a DIR-655. Tried to install it with disc and manually. I have an Actiontec DLS modem. I have one computer hooked to modem via USB and one by cat 5 (RJ45 internet) cable. Both work fine on the modem alone, but I loose internet when I hook up the DIR 655. I 've power cycled, rebooted etc. Nothing seems to work.
During the install, the software claimed it found and another router.
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Posted on Jul 21, 2009
I've plugged the modem into the router and the four lights on the left of the router are on, the middle two blinking; however, despite being able to detect the router wirelessly I am not able to gain...
One thing to try is to hard reset the modem and the router. This will work on an unprotected router that won't connect most of the time.
This link is to the data sheet d-link gives for this router. ftp://ftp10.dlink.com/pdfs/products/DIR-655/DIR-655_ds.pdf
This one is to the software and instillation guides they provide. Select your country from the three. Then there is a link to a FAQ below the two download links that will help you find which of the two that you need.
http://www.dlink.com/products/default.aspx?pid=DIR-825&tab=3
Jun 18, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Need set up CD for DIR 655 D Link wireless router.Is there a site where I can download the driver/installation and configuration program.
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Apr 09, 2010 | D-Link Xtreme N DIR-655 Wireless Router
CAN NOT GET INTERNET FROM DIR-655 TO NS7000S
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Order dlink 655 router and it has arrived, but
Are you trying to install the router.
through the modem.
modem
Then you need to connect the computer to the
router ad the modem to the router.
Feb 04, 2010 | D-Link DIR-655 Wireless Router
I lost my setup cd for my dlink dir-655 wireless router. how can i find the software and drivers?
You can set up your router manually, without the
CD.
directly through the modem.
modem, that means the modem is working fine.
You will need to connect the computer to the
Click Here for more information about the routers
and network
Jan 22, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My macbok pro is not connecting with dlink dir-655
When you open up a browser (Safari, Firefox, Chrome) and type in 192.168.0.1 you can do an automatic set up for your network... That should work :)
Jul 29, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless dlink dir-655 router not working. I installed the router using the Installation Wizard that comes with the installation CD. Everything seemed fine. But at the time I wanted to start surfing the...
just off the firewall or proxy server or anti virus for configuration time and just connect the cable to the LAN port of the router and other end to the PC then try to open the configuration page of the router go to the explorer or Mozilla there you have to type default ip in the addresss bar 192.168.1.1 or 192.168.2.1 try both which is the open then go it after that in cd user manual is there just go through it.
Apr 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Jul 27, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
1,234 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
