Question about Crosley Washing Machines
My washer is leaking from basin while filling up
    Sergeant:
  • 187 Answers
Try these
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
pls rate my suggestion.....
Posted on Jul 20, 2009
Pressure line not filling
I am not a washer repairman. But I have repaired a few & had a run in with a similar problem some years ago. First off, the top of the line has to be vented, otherwise it will pressure lock as it start to fill, ( As your description indicates). I do not know where that vent is located but, you should be able to put a small amount of compressed air on the bottom of the line without damaging anything. The other possible that comes to mind, the samll plastic box at the bottom of the line, ( Assuming there is one on you unit), is, as I remember, a sealed unit. But is it possible that there is a partial obstruction, ( Lint, or whatever), inside there that is metering the flow? If so I would just buy a new unit, they can't be very expensive. Hope that helps. Let me know what you find please.
Mar 10, 2014 | GE WBSR3140DW Top Load Washer
When washer is filling water runs out frrom under machine (not from drain), How can I fix this problem?
The hose from your wash basin to your drain pump is disconnected. Or is damaged. Your going to have to take apart your washer, reconnect any loose hoses and inspect for damage and find your leaks.
Feb 07, 2011 | Kenmore Washing Machines
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Feb 01, 2010 | Bunn VPR Coffee Maker
Pegasus Push Button Drain leaks when you push the button
REMOVE THE LOCKNUT AND CHECK FOR A CRACK OR PIN HOLE IN DOWN DRIAN USE A FLASH LITE IN DRIAN TURN OFF ALL LITES TO CHECK PUT LITE IN DRAIN AND CK FOR LITE IN THE DRIAN PIPE
Mar 09, 2009 | Plumbing
Water is leaking from the unit.
Bunn makes a repair kit for this problem, Call them at 1-800-352-2866
They send the repair kit free,
Jan 29, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
RAT PROBLEMS
you need to reset the switch just blow down the pipe at the opposite end to the switch till it cick again if that doesent work check for air leaks spread washing up liquid on the whole pipe and look for bubbles check wiring also
Nov 30, 2008 | Kenmore 22422 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaks/pours out
its very difficult to answer your question since different machines use different pumps. as for the leak my guess is either a hose has disconnected/torn at the pump or inlet water valve.
Sep 18, 2007 | GE WSM2780W Stacked Washer / Dryer
Washing machine doesn't respond to the low, medium or high water settings and keeps filling. Spin and drain cycle works. Won't stop filling and doesn't go into the wash cycle.
My GE WSM2780DAWW stack set dryer and washer was encountering the same problem (water kept filling up not stopping). I saw this page, but the SOLUTION described didn't really draw a picture for me.
Here's how I fixed the leaking washer. Sitting in front of the washer I removed two small screws on the bottom left and right of the front panel. Then sliding the front panel DOWN, it comes off. This allows a view into the machine. Around the LEFT side of the wash basin you will find a white tube. This tube is about the diameter of a pencil. My tube was not attached, and when the wash basin filled up past the point where it should stop, water came out. Reaching around the side of the wash basin with my left hand I could feel where the white tube was supposed to connect properly. Then I attached the white tube. This fixed the problem.
I left the front panel off for a day to make sure it didn't continue to leak and also for the area to dry out.
Jun 17, 2006 | GE WSM2780DWW Unitized Spacemaker Washer...
Washing Machines Logo
77 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
