Question about LG Televison & Video
My lg 50PS50 plasma tv won't turn on. It clicks multiple times and repeats. The indicator light turns red. It does this after unplugging all devices, unplugging the tv.
Diagnosis Steps: 1. Unplugged TV and waited overnight. Disconnected the Y board and the X board. Plugged the power cord back in. There were still multiple clicks. 2. Waited 6 minutes and disconnected all boards. Plugged in the power cord (one click) then nothing. Turned it on at the TV (1 click) then nothing. Unplugged the power cord. 3. Waited 6 minutes and added back the main board (the one with all of the IO plugs on the lower right of the TV). Plugged in the power cord (multiple clicks). Turned the switch on and off (multiple clicks). Unplugged the power cord. 4. Waited 6 minutes and removed the main board (lower right). Reconnected the bottom center board below the power supply. Reconnected the power cord (1 click). Turned the power switch on and off (1 click). Unplugged the power cord. (Note: The bottom center board is still plugged in.) 5. Waited 6 minutes and added the X board. Reconnected the power cord (1 click). Turned the power switch on and off (1 click). Unplugged the power cord. (Note: The bottom center board, the X board is plugged in.) 6. Waited 6 minutes and added the Y board. Reconnected the power cord (1 click). Turned the power switch on and off (1 click). Unplugged the power cord. (Note: The bottom center board, the X board, and the Y board are plugged in.) 7. Waited 6 minutes and added the main board (lower right). Reconnected the power cord (multiple clicks). Turned the power switch on and off (multiple clicks). Unplugged the power cord. (Note: All boards are plugged in.)
    Sergeant:
  • LG Expert
  • 226 Answers
I think you can aceess this website:Abctay.com
They Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Posted on Jul 09, 2018
    Top Expert:
  • LG Master
  • 76,115 Answers
Sustain board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Nov 16, 2016
SOURCE:
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
LG 32LH30 screen won't power up. Red light at bottom glows hi to low, but no picture. Unplugged and waited overnight, plugged in again, still no picture.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
Apr 10, 2012 | LG 32LH30 32 in. LCD HDTV
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
10 red blinking lights on my Panasonic Plasma TV, will pause for few seconds, then blinks again. TV will not power on.
This is a power supply issue - found a company that has used power supplies, they sell them for $60.00. We recommend a professional install the board because the voltage needs to be adjusted after the install or you could damage something else. The high voltage in the set can KILL you soe be very careful. The web address for the PS board is plasmafix.com.
Jun 24, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
After a lighting my set didnt work any more. I believe the power supply and the main board are burned, albeit screen seems to be OK. Question where can I buy these two boards? Locally they are not...
Try this:
1. UNPLUG TV power cord from wall outlet (or power strip).
2. Trun ON TV (w/o power cord plugged in)
3. Wait 10 full minutes (not any less)
4. Plug power cord back in
5. Turn ON TV.
If power supply & main board are replaced, it doesn't mean it will work. If it were mine, I would do the above steps a few times (or unplugged overnight) before replacing (not repairing) it.
Get a Samsung!
Hope this helps...
Sep 03, 2009 | LG 32LC2R 32 in. HD-Ready LCD Television
My problem is with my 1 1/2 year old Sylvania hdtv. I turned it off yesterday morning and it won't turn on. I have left unplugged overnight for the "factory settings" to go back into effect. I have...
Check the outlet to be sure you have power to it. Then check both ends of the tv power cord to insure that they are actually plugged in. good luck.
Jan 23, 2009 | Sylvania SRT2232S 32" TV
Not turn on i do not have 24v. Was watching TV for three hours when I was finished the set would not turn off from either remote or front panel. Unplugged unit and left overnight. When I plugged the unit...
Good Day,
The most common problem with this Model is the Caps on the Main Board, but to make sure pull the codes. Follow this procedure:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Open Questions:
Televison & Video Logo
387 people viewed this question
Ekse
