Question about Dryers
Squeaking!!!! Hotpoint Aquarius TL61 My tumble dryer is squeaking continously throughout the drying cycle. Is there any way I can fix?  Is it the bearings? Please help as the noise is driving me to distraction.... Thanks
  • Anonymous Mar 19, 2014
    if you push down on the rear of the car it squeak are drive over a bump squeak squeak?
  • 744 Answers
See the video on bearings
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Posted on Jan 12, 2015
Asko T701 dryer,
Squeaking loudly for the full dry cycle
Warrant wet out last year. We complained to the repair man that it was squeaking prior to the warrant running out, he said they just do that. It is now very loud and I know noise = friction, and I am concerned. I looked into it and sprayed some silicon on the belt, but it sounds like the front gasket is the problem.
Is this a common problem, and is there a common fix?
John
Posted on Jan 21, 2008
Depending on the age of the dryer, there is a rear bearing that needs to be replace if its is an older dryer. if its new 10yrs or newer the there is a front bearing support that should be replaced
Posted on Nov 19, 2007
Hotpoint TCM570P Why is dryer squeaking ?
Its probably the tentioner pulley. Remove the panel on the right side (facing the machine)lift off the fan cover ,slide off the fan and remove the pulley (small black wheel at bottom) a little grease should do the trick.scoptrepair1@outlook.com
Feb 24, 2015 | Hotpoint tcm570p Aquarius Condensor Dryer...
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
High pitch squeaking noise throughout the whole drying cycle, getting worse.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 03, 2011 | Magic Chef CYG2000AWW Gas Dryer
My indesit tumble dryer model g74c is squeaking from start of the drying cycle to the end can you tell me what this could be i have replace the drum seal as that was broke now it is still squeaking please...
heatman101
Oct 28, 2010 | Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Mar 23, 2009 | Maytag PYE2300AY Electric Dryer
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Plz rate my solution
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
1,561 people viewed this question
Top Dryers Experts
