Question about Hemera The Big Box Of Art for PC
BBOA (and PO3) can't find images on my HD
I listed the folders with proper paths on my HD as per the OPTIONS instructions. It seems to recognize most of the folders, but not all. It's strange. I keep getting 'insert CD' for about half the images I search for, but I'm sure they are on the HD and I've checked and rechecked the paths. Can't figure it out.
Oh, my OS is Vista. Never had this problem with XP. Please give me good news and tell me there is an easy fix for this. I NEED my images!
Cannot see pc MOV or JPG files on flash drive in Canon SX230
Thanks very much for responding to my problem.
It seems Canon will not allow edited pictures or video to transfer from PC to their digital cameras for viewing.
steps to my problem:1. my canon SX230 created all the parts for my WMV video in MOV format originally.
2. created a movie (WMV format) in Windows Live Movie Maker. Works well and plays on my PC (windows 7).
3. after WMV completed - converted to HD MOV format in 2 different file convert programs and with 2 different HD MOV resolution settings on Both programs. WMV resolution is 1920x1080 (HD). ALL 4 MOV videos play well on my PC in 2 different programs.
Steps getting Canon to see video in playback mode.1. copy MOV video from PC to Flash drive in my card reader in same folder as my original JPG & MOV files, then inserted into camera - does not recognize file.
2. copy MOV file from PC to camera with USB cable. Windows error message. Wrong format - would not copy.
3. Formatted flash drive in camera. Took picture to create DCIM folder, JPG image, and CANONMSC folder with M0104.CTG file .Deleted CANONMSC folder. Copied my MOV video from PC to camera (USB cable). this time copy successful. However camera does nor recognize file.
5. tried again except deleted M0104.CTG file but not the CANONMSC folder. no luck.
It seems Canon will not recognize any file that has not originated in the camera AND has not been altered. Upon researching answers on the NET - many other users of Canon cameras have the same problem with no luck.
Apr 23, 2012 | Cameras
Computer will not reconize external drive
Its a comman error and can be solved according to the operating system. Follow these steps on windows.
  • Open the Start menu and click on the "Control Panel" icon.
  • Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
  • Select "Disk Management" from the list of options on left side of the window.
  • Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."Select a drive letter for the external hard drive to be recognized as and click "OK." The drive will now appear in My Computer.
Feb 24, 2011 | Computers & Internet
My pc is not recognizing my sansa mp3 player clip model 1GB. Do I
Here is the manipulation to be done to remedy this.
To begin, open Windows Explorer and click the Tools /Folder Options /Display. Look in the list "Hidden files and folders" and check "Show hidden files and folders."
  • Right click on the icon "My Computer" from desktop and then click Properties. Then click on Hardware then Device Manager.
  • Right click on the line marked "Unknown Device" and click "Update Driver".
  • Then in the wizard to update the hardware choose "No, not this time."
  • Click "Next."
  • Select "Install from a list or specific location (Advanced)".
  • Click Next.
  • Then click on "Do not search I will choose the driver to install".
  • Choose from the list of hardware USB hub.
  • Click Next.
  • Click on "Disk".
  • A window opens. Then click "Browse", go to C: /windows/inf and select usbstor.inf and click Open.
  • The path of the selected driver will appear in the previous window. Click "OK". The driver will be installrd and you have a line called "Device USB Mass Storage".
  • Choose from the list of hardware "Storage Volume".
  • Click "Next."
  • Click on "Disk".
  • A window opens. Click "Browse", go to C: /windows/ inf and select volsnap.inf select and click "Open."
  • Then the path of the selected driver will appear in the previous window. Click "OK". The driver will be installed and you have a line called "Generic Volume".
Jan 11, 2010 | SanDisk Sansa Clip MP3 Player
My MP3 is not recognize by my computer
install the driver or update the version if it is already installed
  • Click "Next."
  • Click Next.
  • Click Next.
  • Click on "Disk".
  • Click "Next."
  • Click on "Disk".
Dec 24, 2009 | Audio Players & Recorders
Batch convert image files, that keeps a folder tree?
If your not using version 2.20 then upgrade because there is no limit according to the manufacturer.
Dec 14, 2009 | Microsoft Windows XP Home Edition
Program won't recognize folders on my hard drive
i want all flash script.
like on click and all
please help
Jan 23, 2009 | Hemera The Big Box Of Art for PC
Can't open file.
Check Hemera settings and ensure that the path for the picture files is the right one, where files are stored.
Hemera usually reads the picture files from CD/DVD unit, if your system had renamed the DVD form D:\ to E:\, for example , then Emera wont be able to find files anymore.
Solutions to this problem.
Check file source folder on Hemera settings, and assign the right CD path.
Do a system restore to a date before having the problem.
If still no luck, then Windows may be corrupted, in that case , the standard procedure is reinstalling Windows, then reinstalling Hemera, and the rest of the software.
Jan 02, 2009 | Hemera The Big Box Of Art for PC
HP Deskjet F2200 All-in-One SCAN green light flashes but does not scan
Error: “HP Cue Scanning Flow component has encountered a problem and needs to be closed”.
The problem is caused by HP software not installing the file path to the scanner correctly in XP, so if you run a registry cleaner such as RegCure it will delete the file path.
OS: Windows XP.
If you encounter this error message please follow the steps below:
1. Go to registry by clicking on Start/Run then typing in regedit and hitting enter.
2. Go to HKEY_ Local_ Machine\Software\Hewlett-Packard\DigitalImaging\
3. Click on the Digital Imaging Folder and in the Right Hand Side Pane and check if the String Value “ProfileWritePath” is present and Value is set to %APPDATA%\HP\Digital Imaging\Data\Destination
4. If the Sting Value is not present right click and then click on new and then click on String Value Name it as “ProfileWritePath” and then right click on that and click on Modify and make sure that the value is set to “%APPDATA%\HP\Digital Imaging\Data\Destination” and close the registry editor.
5. Then go to My computer C:\Documents and Settings\All Users\Application Data\HP\Digital Imaging\Data and check if the Destination folder is present. If not create a new folder and name it as “Destination”.
6. If you are unable to locate the Application Data folder under All users, click on Tools and then click on Folder Option. In the Folder Options Window click on the View tab and under Hidden Files and Folders make sure that “Show Hidden Files and Folders” is checked and then click on Apply and then click on OK..
7. Then Make sure that the same that the HP\Digital Imaging\Data\Destination folder is present under all user profiles Application Data folder.
8. Run Regcure and after the scan check the file/path errors and tell it to ignore the HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\digitalImaging ProfileWritePath= C:\Documents and Settings\ (whatever your file path to the destination folder is)
Now it should run flwalessly even after you run regcure.
For other registry cleaners I'm sorry but you will have to find out how to tell your cleaner not to delete the erroneous file/path error.
Graham Sept 13th 2009.
Oct 14, 2008 | Office Equipment & Supplies
Jun 26, 2008 | Hemera The Big Box Of Art for PC
Hemera The Big Box Of Art for PC Logo
59 people viewed this question
Top Hemera Computers & Internet Experts
David Payne
David Payne
Are you a Hemera Computer and Internet Expert? Answer questions, earn points and help others
