Question about Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front
My Avid Juicy 3 front brake seems to pulsate when pressure is applied to the brake lever and the braking is very uneven...almost like a pulse of sharp braking at one point of revolution. Is there an air bubble in the brake line?
  • 125 Answers
The brake disc may be warped from excessive heating. This may be caused by a dragging brake pad. the disc may have been bent from an impact.
This can also be caused by the pins holding the brake caliper being stuck. Try some WD40 on them and tap them (gently) to free them.
Posted on Jul 20, 2009
How to replace rotors on 2004 nissan pathfinder
There are hard spots on the rotors. Take them to an automotive machine shop to see if they have not worn so much to be resurfaced. If so then you'll have to buy new ones.
Aug 19, 2014 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Bleed brakes
There are a couple youtube videos on bleeding lines that will help you out. In a nut shell though you have to go to each wheels bleeder valve and loosen it while pressure is being applied to brakes slowly. As the pressure is applied either air or fluid will come out. When you get nothing but fluid you are done at that wheel. tighten bleeder screw and and move to the next. After each wheel is bled you need to fill up the brake fluid again. Now this is just a nutshell explanation and you NEED TO WATCH THE VIDEO for full details on how this is done and to understand it. Go to youtube and type in brake bleeding. They will come up.
Sep 29, 2012 | Avid Juicy Five Mtb Hydraulic Disc...
I bought avid juicy ultimate front and rear brake set no upper clamp to secure brake to handlebar, match maker setup was used. How or where do I find oem clamp?
I am assuming you are looking for the clamp portion of the brake lever.
If you do a google search for the following you can find several options on-line, or go into your local bike shop and have them order for you, they may even have in stock if they do alot of work with Hydraulic brakes.
Search: Avid Juicy Brake Lever Clamp or Avid Hydraulic lever clamp.
Here is a link as an example of a result.
Dec 23, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
My juicy ultimate brake lever (rear) has a lot of play and retracts slowly after engaging.
Have you ever oil & adjust the wire cord?
If no then oil the brake and adjust the wire cord which is being adjusted with the bolt-screw type mechanism. If you don't know the braking mechanism visit the authorized mechanic and show them as it is crusial part.
Jun 04, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid Juicy 7 disc brakes:The front wheel was removed and the brake lever squeezed while the wheel was off. The front wheel goes on, but does not spin freely. It turns easily, but not freely like it...
It sounds like you have a piston that is not fully returned and is sticking.
Get a big flat bladed screw driver, take the wheel out and very carefully insert the screw driver into where the disc would sit and use the screw driver to try and push each brake pad back in without damaging your brake pads.
If this works go to a local bike shop and ask them for a avid brake insert for transporting your bike so this does not happen in future! :)
Jan 13, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid Juicy five system leaking fluid
Your brake failed and you need to take it to a good bicycle repair shop in your area. Hydraulic brakes on bicycles are not easy to self service as you need specialized tools and the proper replacement parts.
Aug 23, 2009 | Avid Code Hydraulic Disc Brake
Break avid juicy three stuck
There are some ways this can happen. If you accidentally apply pressure to that brake lever with the wheel removed you will have to gently force the pads apart with something that won't damage them and then bleed that brake. You will need a bleeding kit for that model as they are unfortunately mostly all different because of the fittings needed. The other problem is a sudden application of the brakes in an emergency will cause the seal in the brake lever in the piston to blow which requires part replacement and a brake bleed. If you want to attempt the repair yourself there is info at www.Parktool.com. In either case you will still have to go top a good bicycle repair shop for the necessary tools, parts,and supplies. Ask for brake wedges while you are there. They are fairly cheap plastic wedges that keep your pads the proper distance apart when you are transporting the bike with the wheels off. Hope this helps.
Aug 05, 2009 | Avid Code Hydraulic Disc Brake
Brake pads tightening up
use a flat screw driver and push the pads back in on the calliper. Be gentile though.
Jul 30, 2009 | Avid Code Hydraulic Disc Brake
Bought a set of avid juicy seven ultimate brakes,i squeezed the brake lever and now the pads are shut tight how do i slacken them off again!
take the wheel out insert a very large flat bladed screw driver up into where the rotor would sit and lever the pads back in very gently with the screw driver.
if this does not shift them they will need re-built by a Sram bike shop.
Mar 23, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front Logo
919 people viewed this question
Top Avid Cycling Experts
Michial Gueffroy
John Egan
John Egan
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you an Avid Cycling Expert? Answer questions, earn points and help others
