Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE JVM 1490, digital display will not light
This above the cooktop oven is in a motorhome I bought new in 2005. Every time I hook to shore power or start generator, oven says "set clock" now the digital display does not light up. Inside oven light goes on, popcorn button starts microwave, and bottom light works fine. This microwave has only been used a dozen times. Is there any way to fix this cheaply, or should I throw it away and get a whirlpool?
Dwight S. Meyer
  • dmeyer213 Jul 20, 2009
    That is not the problem. In a motorhome, unless it is permanantly hooked to shore power, each time you use it, you must reset the power. MY problem is: the "start clock" flashing light no longer comes on when I connect to shore power. I know the microwave has power, because if you hit the popcorn buitton, the microwave starts, interior light comes on, and the dish rotates. The display never comes on, therefore I cannot set the clock, timer, or other features that require the digital display;. Clock settings, as well as timer is set on this model by rotating a knob in the center of the panel.
    Digital display does not light up on GE JVM 1490 above the cooktop oven. Unit has power, but the display should read "set clock". I know the oven is getting power, because recepticle is hot, light comes on when you open door, and if you select "popcorn", microwave starts as it should. Time and temp are set by rotating knob in center of panel, and without the display lighting up, you cannot set time or temperature. This oven has only been used about a dozen times.
  • 3,741 Answers
Its not all the power problem.its the control panel problem.there can be two possibilities. 1)the control pannel wirings are got loose and needs to be removbed and refitted. or 2)the control pannel boartd is faulty.it needs replacement. this will help.as the control pannel is the thing through which you get light in the front of the unit.to view its functions. you can get new replacement parts at www.repairclinic.com thanks.please do rate the solution.thank you for using fixya.keep updated
Posted on Jul 20, 2009
    President:
  • 1,714 Answers
Every time you switch power source, it interrupts the power briefly. This is basically a 'power loss' to the unit and it needs to be reset just like at the house when you have a power loss. I don't know of a way to prevent this other than ignore the clock issue on the panel.
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave®
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
Service manual jvm 2070 microwave
First of all if you're having problems with the touch screen, display, or keypad on these models, separate parts are not available, and you'd have to order the entire control panel assembly, which runs a few hundred to several hundred dollars, depending on the exact model.
Luckily, problems with the cooktop lights or fan can be remedied by ordering a new smart board or having it repaired.
That said, the closest I have come to a service manual for these is the technical manual here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 08, 2011 | GE JVM2070 Microwave Oven
Our GE JVM 1653 spacemaker microwave looks like it is working but the food doesn't heat up. It lights up and goes around but no heat? Whats up?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ysss
Jul 06, 2010 | GE JVM1653 Microwave Oven
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need manual for GE Profile
LOOK HERE;
http://www.serenitysys.com/******/archives/GE%20RV%20Microwave%20manual.pdf
Oct 16, 2009 | GE JE1640 Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Surface Lights won't go off
This is a problem with the control panel assembly, which we repair nationwide for $39.95. Full details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 10, 2007 | GE JVM1850 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
37 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
