Question about Raymarine C80 GPS Receiver
Takes sometimes upto an hour to get fix 120/ c80
Takes sometimes upto an hour or more to get fix 120/ c80
  • 43 Answers
Look after your software version it shoud be 4.29 after this make a reset (you will lost all the data like waypoints routs and other)
Posted on Oct 13, 2009
    Brigadier General:
  • 4,090 Answers
Bad internal battery
Posted on Jul 22, 2009
I have a old raymarine c80 navigation sometimes it gives me a fix when i turn it on and sometimes it will not. Do i need a new antenna if so what kind.
The issue is related to the antenna, either bad connection, low voltage or faulty gps. Start by checking the voltage supplied to the antenna (most probably through SeaTalk from the plotter), if you find this to be 11V or bellow - beef it up by adding external 12V. You can also check the wiring, if all looks ok - it is time to get a new gps antenna. Raymarine has a retrofit pack for the new RS130 which also includes SeaTalk ng converter. With some luck it's only the power...
Oct 22, 2013 | Raymarine C80 GPS Receiver
C80 GPS
Please remove the power cable form the unit and wait for 30 min then replug it switch on ,,let me if your facing the same problem again...............
Jul 07, 2008 | Raymarine C80 GPS Receiver
I have a Raymarine C80, when I turn it on all I see is a white screen sometime with some line running from top to bottom
It is a bad connection in the jockey board, your local technical dealer should be able to fix this easly.
Oct 03, 2013 | Raymarine C80 GPS Receiver
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
I have the C80 system networked thru the E55058 SeaTalk. After sitting for a month without being used it now will not boot...message on AutoPilot screen reads "STLK failed" and I cannot get any fix or...
Hi, well in my professional opinion with what i call "Mission critical" devices, you should NEVER EVER take chances. If it has failed now, then when you are half way across the Indian Ocean it may fail again. Your life may very well depend on an instrument like this. If it were me.. I would spare NO expense and simply replace it. I would never ever trust a Repaired device, I am speaking from 35 years of experience. Replace it now.
May 22, 2010 | Raymarine C80 GPS Receiver
No fixed postion has ? over gps icon in upper right corner of unit
touch lower right hand corner and see if it reboots software. will probably lose all info saved
May 30, 2009 | Raymarine C80 GPS Receiver
GPS antenna
If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
Hope this helps.
Jun 04, 2008 | Raymarine C80 GPS Receiver
42 inch plasma
TURN OFF THE MAINS AND THEN SWITCH IT BACK ON
Jun 06, 2007 | Samsung HP-R4262 42 in. Plasma Television
Epson C80 - single color won't print
If you still have this problem, please open a new comment & I promise I will help you fix it! Otherwise I think we can consider it solved!
Mar 25, 2007 | Epson Stylus C80 InkJet Printer
Raymarine C80 GPS Receiver Logo
202 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
