Most serious scope owners know that cost is no reason to get a scope. The cost sometime exceeds the value of what it is on. Cheap scopes are not worth the effort to work on.
Air Rifle Scope Mounts/Rails. Air Rifle Scope Mounts/Rails. Air Rifle Sights. Replaceable sights for air rifles. Air Rifle Spare Parts. Replaceable parts for air rifles.
I have one of the BIG CAT rifles and can shoot under 1" groups. First Check the gun and be sure it is tight in the stock. I had to remove the front screws and pot nylon washers under them to get the stock tight! Second. I could shoot decent groups and the they would move! I replaced the scope mount with a better quality better fitting scope mount. Be sure it has the stop pin that fits in the hole in the top of the rifle or they will move to the back and never be stable. Third. I replaced the Gamo scope with a Leupold 3X9 varix 2. I am not sure about the Gamo scope but while I was mounting a scope I decided to try the Leupold. I have shot some 5 shot groups from a good rest that was less than 1/2". The factory scope mounts looked like a bad fit on the groves of the rifle and looked canted. The best pellets I found are the PREMIER HOLLOW POINT and some of the worse were the GAMO FLATPOINT!
no its not normal,,,check that the piston crown is not braking up as if it was the piston would smack into the breach block causing the hard thump on firing
If you are seeing an X you need to loosen the scope rings, re-level your scope and re-tighten the scope rings. 10-20 in/lbs on the ring screws, 15-30 in/lbs on the mounting screws. Typical configuration of the turrets is one on the top, one on the right side.
