You will need to remove the shrouds on wither side of the Exercise bike. You will see on each crank, or at least one of them, there is a cotter pin with a bolt The cotter pin needs removing and you will be able to turn that pedal arm to 180' to the other one. Spare parts appear to be obsolete, but you should get parts for the crank arm from a good cycle shop. Very often the cotter pin needs to be filed to fit. Tightening the nut locks it in place. There are two videos, the second one refers to cycles which is where my experience comes from.
Unfortunately the other answer is incorrect, as you did not explain that yours is not a bike but rather a bicycle exercise machine. It appears that unit uses a crank assembly unlike that which comes on bicycles. I would suggest you contact the manufacturer: New Balance Fitness Equipment Customer Service Department 1400 Raft Road SW, Canton OH 44750-0001 1-800-292-5009, Monday through Friday 8:30am to 8:0Opm, Eastern Standard Time
You wil need a couple of special tools, or be fairly creative with the tools you have.
remove the dustcovers in the crank arms at the crank axle
loosen the crank retaining nut/bolt.
thread in a chank puller and pull the crank arms.
remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
remove adjustable bearing cup.
remove axle and bearings
replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
