Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Hello, My SyncMaster 943BX monitor will not "wake up". It keeps displaying Analog, Digital, Analog... Could you help me with this problem? Thank you.
  • Anonymous Mar 26, 2014
    Picture is too dark
  • 202 Answers
Monitor is not getting signal from video card, either the cable monitor or video card is bad.
Posted on Jul 20, 2009
What does dvi mean
Hello figment_of_u,
DVI stands for Digital Video Interface. They are used for direct digital connections between source video (namely, video cards) and LCD monitors. This provides a faster, higher-quality image than with analog, due to the nature of the digital format. All video cards initially produce a digital video signal, which is converted into analog at the VGA output. The analog signal travels to the monitor and is re-converted to a digital signal. DVI-D eliminates the analog conversion process and improves the connection between source and display.
Hope this helps you understand what DVI is for. Thank you for choosing Fixya.
Feb 12, 2012 | HP 2009M Monitor
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
My Samsung Syncmaster 943BX will not wake up from sleep mode sometimes. Sometimes it comes right up, other times it may be 5,10,20 minutes before the display wakes up.
You probably have caps failing in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 29, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
SyncMaster 204B - when pc goes into blank screen mode (normal) the monitor does go black (normal). But when waking up PC the monitor just start flashing the screen extremely fast, progressing slower and...
Yes, The repair is simple, it requires changing out 5 capacitors. We have a full repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ We also have a parts kit available for $12 shipped.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My Samsung Syncmaster 930B was working fine unti I disconnected and then reconnected it to my computer. Now I get a black screen with a roaming box that says, "check signal cable".
Hello
1st Pull all power from pc from the wall.Plug back in and start pc up.
While starting hold down the f8 key and select safe mode.
once in go to control panel and select display.
set resoulution to default 60 hz and screen size to 800 by 600.
Reboot.
You may need to readjust your screen again.
Hope this helps.
Jan 14, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
I have a Samsung Syncmaster 2053bw. Screen
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW. Reply!
Jul 07, 2009 | Samsung Computers & Internet
Check signal cable
Turn off the monitor first.
Hold down Function button and click F8 key to tell the laptop to send signal to the monitor.
Apr 20, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
480 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
