Compressor trie to start, but don't.
Coleman RV roof air 13,000 btu, I think. oldie 1978. Fan works fine, but when I switch to compressor mode, it tries to start momentarily, but doesen't.Friend says it sounds like capasitor problem????????
Coleman RV roof air conditioner. Model 6731B901
  • 6,674 Answers
Capacitor is good place to start, once you confirm you have proper voltage getting to the unit.
Posted on Jul 20, 2009
Fan runs. Why won't the compressor start?
probably a relay on module either bad or not communicating with thermostat.
Jul 12, 2015 | Coleman 15000 Btu Rv Roof Air Conditioner...
Btu of coleman 7830-901
That should be a 30,000 Btu unit. Its been a while since I worked on them. The 78 is the series or model, the 30 is the capacity or btu's and the 901 indicates it is a Copeland compressor.
Jun 09, 2014 | Coleman Air Conditioner Shroud Rv Roof Top...
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Coleman rooftop a/c hums in all modes, does not start
Replace the start capacitor for the fan and compressor. Check all the wires to the capacitor.
Aug 29, 2009 | Dometic Rooftop RV Air Conditioner
Coleman mach 3 rv roof mount ac
You will need 12 vdc (battery or converter) for controls to work, and 115 VAC (hydro) for fan & compressor to work. With your fan obviously working, that tells me you have both already but compressor may not be kicking in. Do you hear a "moaning" sound or see lights dim when switched to cool?
Aug 17, 2009 | Coleman Mach III Air Conditioner
1 yr old 15,000 btu Coleman fan blows compressor not working
The power supply or compressor coil may be faulty. There could be shorted wire, open circuit, bad relay.
Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
Coleman RV roof air
I think you have a high pressure switch that has tripped. open up the case and look for a switch connected to the line with a resettable button in the case it is not resettable you will have to have a professional replace it. If you are able to reset it make sure to clean the condensing coil on the top side before running it again as most likley this is what may have caused it to trip.
Jun 22, 2008 | Dometic Rooftop RV Air Conditioner
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Heating & Cooling Logo
256 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
