Question about Goldstar KG6000R Window Air Conditioner
Exact same thing happened to me
I have the exact problem with a brand new portable AC. After hearing the pop noise there is no power going into the unit. Does this have anything to do with having it plugged into a 20 amp exclusive socket designed for a window AC while the unit states that it takes 6.5 amps? Is this something that any air conditioner repair can do or a professional electrician should handle?
  • finksmart Jul 20, 2009
    Thanks Acfxr. The pop noise came from the unit itself. The breaker did not trip. Plugged a lamp to the same socket and it worked fine. Tried resetting the GFCI on the plug came with the unit and no luck. Voltage is 115v on the unit. Not sure the circuit voltage but the socket I bought at homedepot is 220 volts.
    Champion:
  • 233 Answers
The 20 amp circuit should more than handle a 6.5 amp load, the 6.5 is the rating of the operating AC not of the circuit that is required to be attached to it. If the "pop" noise is the breaker tripping the circuit may be miswired, the unit mayhave a short to ground, as the circuit breaker is designed to trip on an over amp situation or a situation where 20 amps is exceeded. Di you verify that the circuit voltage id correct, eg: 220 volt or 110 volts. and that it matches the unit nameplate.
Posted on Jul 20, 2009
My impala runs great but when i go to leave and stop at a light and shes in drive sitting at the light she makes noise like loss of power or stalling idk i went to aotuzone they checked my alternator its...
When the AC is turned on, a number of things happen: the cooling fan is engaged, the idle speed is increased to account for the additional load of the compressor, and the AC clutch is engaged. My guess is that what you are hearing is the AC Clutch rattling due to a worn input shaft bearing. As soon as it is engaged, the noise goes away. It is possible that something else is going on here, but I would be tempted to focus on the AC compressor as the SOUND portion of your problem. When you say "...she makes noise like loss of power or stalling, I am not sure what you mean. Is it a noise, or is it actually losing power. With no MIL (check engine) light on and if the noise goes away after servicing the compressor, I would say you are fixed up. Good Luck.
Jul 10, 2014 | Cars & Trucks
My Proform 6.0 ZE elliptical is draining new batteries within hours and humming. It makes LOUD popping and static sounds when using the AC plug in.
DEAR
AT FIRST YOU COUNT YOUR BAT AND MULTIPLY 1.5 THEN YOU USE A ADAPTER AC TO DC WITH SAME VOLTAGE LIKE 6 V OR 9V DC
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 21, 2017 | Proform Pro Form 6.0 ZE Elliptical
Dyson dc07 is making weird noise
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC07 is making a popping noise in use. Unusual noises can be caused by a number of different issues, and in order to determine exactly what's causing this we would need to hear it. I'd encourage you to call our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). One of our experts will be able to listen to the machine over the phone and diagnose the cause of the issue.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Occasionaly popping noise with my visani wine cooler
The popping noise you hear, probably is just the refrigerant going through the lines.Since they started using the new refrigerant that happens alot. Nothing to worry about.
Apr 12, 2011 | Refrigerators
Something went pop and them the power went out and won't power back on?
Most probably a capacitor exploded either in the AC adapter or on the laptop's motherboard. In order to find out where the damage exactly happened, you can either test your AC adapter with another similar laptop, or test a new AC adapter with your laptop. Alternatively, you can test the output voltage from your AC adapter using a voltmeter.
If the AC adapter turns out to be working properly, then the damage happened on the motherboard. You will need to disassemble the laptop to get access to the motherboard & inspect it. The exploded capacitor could be replaced with a new one to fix the problem.
Jan 12, 2011 | HP Compaq nx6110 PC Laptop
Will Not charge with brand new a/ power cord it will at times power on if moved the right way but quickly powers off if moved the port inside looks to be fine But I hear there is a pin type thing inside...
The problem is with the AC adapter itself and is a very common problem with Dell AC adapters. My suggestion would be to get an aftermarket AC adapter that can be purchased on eBay as the Dell adapter is around 100.00. You can pick up an aftermarket one on eBay for around 20.00. The problem is a resistor inside the AC adapter that senses when a Dell branded adapter is inserted. What happens is that the resistor will get damaged and since it doesn't recognize the charger as a Dell branded one anymore it won't charge. However it will still run the laptop as long as it's connected. A lot of aftermarket AC adapters bypass this function and work perfectly fine.
May 29, 2010 | Dell (04U621) for Latitude D600, Inspiron...
Dell Inspiron E1705, Faint Black Screen on Battery Power
the first thing i would do is do a bios update for the machine whilst using AC power, that may well iron the problem out, if not then there is a problem with the laptop itself i.e. a power drain, sizzling and popping noises is not good at all and could damage the machine further, remove the battery and check the connections on the laptop, dust and hair conduct electricity, it could be as simple as that, it is also a known fact that some lithium batteries are faulty and have been known to blow up whilst in use.
Go to the laptops support website to find out if they have been having problems with batteries and if there any returns proceedures
best regards
Nov 17, 2008 | Dell Inspiron 1501 Notebook
No power and there is a clicking noise in ac power adapter
hearing a clicking sound inside an ac adapter is something very unusual. it could be possible that this is a factory defect. call hp and ask for a replacement of another brand.
Jun 17, 2008 | HP Pavilion dv1000 Notebook
Popping sound
Karmakin, the popping you hear is probably the refrigerant entering the evaporator coils. Some are worse than others. You need to call for service since this is brand new. Sometimes they can insulate the cap tube going into the evap and the dryer to supress this noise. Best thing to do is call for service...Catriver..post back.
Sep 25, 2006 | Whirlpool Gold GB2SHDXPS Stainless Steel
Goldstar KG6000R Window Air Conditioner Logo
259 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
