Lag in video to audio on Westinghouse LCD 26' TV
The audio signal is ahead of the video. I thought it was the TV and returned it and got another; same problem. It take about 30 minutes for it to happen after the set is turned on or reset. I am using the coaxial connection from the Verizon digitial set box to the TV. I have used three plug RCA cables with the same problem.
Any suggestions
  • 1 more comment
  • mr_cowboy Dec 09, 2007
    When watching DVD or DVR recorded program the audio doesn't match video. One is ahead of the other. Any solutions
  • seashorehi Dec 29, 2008
    I have the 26" westinghouse, and it does not take long for the audio and video to get out of sync. It's maddening and I only use it as a computer monitor now.
    Any fix ideas would be appreciated, bec otherwise it is a great display and sound with a decent tuner.
  • Judy DiGiano
    Judy DiGiano Feb 16, 2009
    I have a sony xbr and it's a year old; the audio lags and I don't know how to fix it. If you look at their lips what they're saying doesn't match. Any suggestions. It's a big one installed on the wall and hooked to my sony surround sound receiver.
Register your tv (whether under a year of date of purchase or not) and get a firmware update. It is simple and works like a charms, sync of voice and images is great afterward.
Make sure you unzip the thumb drive download b4 installing on tv.
Posted on Dec 29, 2008
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
Need help to hook older recorder dvd unit
I am assuming you are looking for a way to get a video signal from the TV to the recorder. Most TVs already have a composite video input. If you want to get a signal to your recorder, there are HDMI to composite video converters available for around $30 US. There are also composite video to HDMI converters. You can then get the audio from the audio out (headphone) jack.
Sep 21, 2013 | Toshiba 26 26AV502R 26 in. LCD HDTV
My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
May 01, 2010 | Sharp Televison & Video
Westinghouse tv turns off by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Jan 19, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
LG 26 inch lcd. Recently it loses the signal from sky remote eye
hi! maybe there is a problem on power supply section or loose connection.
Sep 01, 2009 | LG 26LG30 26 in. LCD TV
I connect a WD TV to this TV and there is no video/audio signal.
please check to see which video you connect to for example video 1 then go to source/input on remote and enter video1 . if this don"t work the TV has a picture output problem.Let tv repair guy look at it.
Aug 18, 2009 | RCA L26HD32D 26 in. LCD HDTV/DVD Combo
Lag problem - Guitar Hero / Wii / Philips 32PF5321/10 tv
Usually the video lags behind the audio. The reason is the video, in many TVs, takes longer to process than the audio coming direct from the device. To solve this, the audio needs to be delayed. This can be done by 1. Using the tv audio output. Most TVs sync the audio to the picture and this 'synced' audio is available at the output jack of the tv. 2. Delay the audio coming out of the device. Many home receivers have a 'Lipsync' feature designed for this issue. The setting is usually between 50 to 500 milliseconds of delay, depending on the TVs video processing time.
I hope this is clear and can help.
Mar 04, 2017 | Philips Televison & Video
No video/audio when pressing remote control or on the TV set
Moved my TV to another satellite receiver.
I received picture & audio.
Then I moved the TV back to its original position.
Now it works OK.
I probably hit a button that shut off my picture & sound.
I am mystified.
Thanks anyway.
Gerry............................;-))
Apr 13, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Westinghouse 26 power problem
Try call Westingtonhouse for service at this number. By Phone:
For help with the following: • Installation or operation of your Westinghouse Digital LCD products • Warranty assistance • Service to obtain service an RMA (Return Merchandise Authorization) is needed • Refurbished product service request Our service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
Note regarding LCD Drivers
Since Westinghouse LCD TVs and Monitors are plug-and-play devices, they do not require any drivers. If your computer is unable to display at the recommended resolution, please check your graphics card to see if it supports the recommended resolution. You can periodically check the graphics card manufacturer's website for any updates. I hope this helps you with your problem.
Jan 09, 2009 | TruTech PLV16320 Television
Westinghouse lcd 26 inch
I found that with my Westinghouse SK26H240S lcd tv. that when you turn down the blacklight feature you get a hum thru the audio. so I just turned the blacklight feature to the max and the problem went away, no more audio hum.
Sep 11, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
624 people viewed this question
Top Televison & Video Experts
