Question about Waterway Above Ground Hi Flo Pump
Pump has minimal suction in filter position
Power flo matrix pump has minimal suction in filter position
  • 32 Answers
Particle screens may be plugged or the impeller is wore out
Posted on Jul 20, 2009
Removing the lid from a hayward power-flo matrix
Too Much Pressure????
Are you trying to remove lid when the pump is on? NO, NO, NO
If not, then good! If you have valves before and after the equipment, then close them. Then remove the small 1/4" drain plug to empty the pot. Then try removing the lock ring and open it up.
Jul 13, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
How to replace seal on hayward power flo matrix?
if seals leaking ruining bearings next to go replace whole unit
Jul 21, 2012 | Hayward 1hp Power Flo Matrix Above Ground...
How do I take my hayward Power Flo Matrix pump apart to replace the shaft seal?
The instructions are in your owner's manual, which you can also find on Google. No specialty tools are required.
Aug 04, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
No suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
No water in pump after running for short time
suction side leak... your grabbing air somewhere in the suction line.... take a hose at low pressure and with the pump running put it over various parts of the suction line... including your pump lid... if the problem goes away and you have no more air in the pump then you know what your problem is
May 22, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Jul 19, 2009 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Waterway Above Ground Hi Flo Pump Logo
125 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
