SOURCE: how do i record the main greeting on a comdial edge 120
I just went thru this.
Push the Voicemail button, hit # until it asks for mailbox #, then hit 70 for password. Wait for main menu, then hit 3 for options. Then hit 2 to record your greeting. Now the tricky part,,, I don't know if these are all programmed the same way, but it will ask for the number of the box you wish to change, ours is 800, then follow along.
good luck!
What I'm trying to find out is how you can import a prerecorded message (mp3) as your greeting.
SOURCE: How do I turn on/up the ringer on the Comdial
with the phone in its cradel hit the volume up button till you get the desired ringer volume
SOURCE: I have a Comdial Edge 120. When a call is
I'm not familiar wiht Edge terminology, but the idea is you set the transfer recall time to something less than the call forward to voicemail. It means that any calls to voicemail have to be direct transfers and there may be some auto attendant issues.
HTH
Carl
SOURCE: how do I set the
Try this: DX-80 Time Change Instructions Software Revision F32 and later From the attendant station or an phone with attendant password: 1. Press Feature #0 from the telephone dialpad. You will be prompted to enter the Tenant Group number. This is typically 1, however it can be set for Tenant Group 1-3. 2. Press Save and enter in the attendant password (default is 9999), then press Show. 3. Press the Next option until the display prompts you for the System Time. Press Show. 4. The last 2 digits of the year will be displayed. If you do not need to change the year, press Next. If you need to change this value, press Chg, enter in two digits for the year and press Save then Next. 5. The current month setting will be displayed. If you do not need to change the month, press Next. If you need to change this value, press Chg to cycle through the 12 months. When you reach the appropriate setting, press Next. 6. The display will show the currently programmed day of the month. If you do not need to change the date, press Next. If you need to change this value, press Chg, enter in two digits for the date and press Save then Next. 7. The day of the week (Sat - Sun) will now be displayed. If you do not need to change the day, press Next. If you need to change this value, press Chg to cycle through the days of the week. When you reach the appropriate setting, press Next. 8. The current hour will be displayed. Press Chg and enter in two digits for the hour in military format. Press Save and Next. 9. The display will now show the programmed minutes. If you do not need to change the minutes, press Next. If you need to change this value, press Chg and enter in two digits for the minutes (01- 59). Press Save then Next. 10. You will be returned to the top level off System Time. To exit Attendant Administration, pres On/Off button twice. Software Revision F2x From any telephone: 1. Press Feature # * and enter in your password. (Default password ########). 2. Press Show and enter 08 14. 3. Press Save then Show. 4. The option to change the Year will appear. If you do not need to change the year, press Next. If you need to change this value, press Chg, enter in two digits for the year and press Save then Next. 5. The option to change the Month will appear. If you do not need to change the month, press Next. If you need to change this value, press Chg, enter in two digits for the month and press Save then Next. 6. The option to change the Day will appear. If you do not need to change the date, press Next. If you need to change this value, press Chg, enter in two digits for the date and press Save then Next. Printed in the USA Page 2 of 2 7. The option to change the Weekday will appear. If you do not need to change the weekday, press Next. If you need to change this value, press Chg, to select the weekday, and press Next. 8. The option to change the Hour will appear. Press Chg and enter in two digits for the hour in military format. Press Save then Next. 9. The option to change the Minutes will appear. Press Chg and enter in two digits for the minutes and press Save.
10. Press the On/Off button to take the phone out of programming mode.
