Question about Acer Aspire 5050-3242 Notebook
Well the computer has been repaired 3 times in 2 years. 2 times of redoing to XP..The third time was the hard drive being replaced. Then was formated to XP again. Now, I don't have a restore point due to the thing being so messed up. How can i redo my computer to factory settings. I think its formatted to Windows XP server pack 3 now. Which is kind old.
  • Acer Master
  • 3,051 Answers
Hello there.
sounds like you have had your hands full. Unfortunatly it is not going to get any better when they formatted the harddrive you lost every thing that was on the harddrive including any factory settings. the service pac 3 that you see is the latest service pac that is out now. about the only thing that you can do is contact acer's techinal support to see if you would be able to get a cd for the computer, it would have the factory settings and operating system on it, ok sorry to hear about the problems that you are having and i hope that i have been able to give you some kind of help.
best regards mike
Posted on Jul 20, 2009
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
Need to factor reset,|NOT REBOOT, for acer aspire 3630 windows xp
Hi and welcome to Fixya..
Reinstalling Windows XP on an Acer Aspire 3000 is fairly straightforward. You may need to reinstall Windows XP due to hardware failure, a virus infection, major hardware changes or a hard drive upgrade. Whatever the reason, you can do the reinstall yourself at home. The reinstall will take anywhere from 1 1/2 to 3 hours, depending on the size of your hard drive. Be aware that reinstalling Windows XP will format your hard drive, getting rid of all data on, so you'll want to back it all up on a media device.
  • Step 1
Back up all data on your computer before reinstalling.
  • Step 2 Insert the Windows XP disk and restart your computer.
  • Step 3 Press any key when prompted to begin running the disk.
  • Step 4 Press F8 to agree to the terms of service.
  • Step 5 Choose the partition you want to reinstall Windows XP on. This is usually "C:" for most users.
  • Step 6 Choose the type of format. You can choose either "Quick" or "Full" for NTFS systems. A quick format only takes a few minutes less than the full format.
  • Step 7 Wait for the format to complete. The Windows XP installation wizard will begin. You will be asked to choose your time zone, computer name, and to input any network information. Otherwise, the reinstall will run by itself.
  • I hope this helps
    Oct 15, 2009 | Acer Computers & Internet
    HDD Partition help
    Important If you follow these steps on a hard disk that is not empty, all the data on that hard disk is permanently deleted. We recommend that you back up your hard disk before you follow these steps.
    To partition and format your hard disk by using the Windows XP Setup program:
    1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
    Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
    2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
    Note If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver.
    For additional information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base:
    314859 Limited OEM driver support is available with F6 during Windows XP Setup If you are starting from the Windows XP Setup disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after you insert each disk.
    3. At the Welcome to Setup page, press ENTER.
    4. Press F8 to accept the Windows XP Licensing Agreement.
    5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
    6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition.
    7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
    8. Repeat Steps 4 and 5 to create additional partitions if you want them.
    9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
    10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
    Format the partition by using the NTFS file system (Quick)
    Format the partition by using the FAT file system (Quick)
    Leave the current file system intact (no changes)
    The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions. 11. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue. After the Windows Setup program is completed, you can use the Disk Management tools in Windows XP to create or format more partitions.
    For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base:
    Oct 19, 2008 | Computers & Internet
    My computer cannot install os
    You need a new hard drive mate..
    not all hard drive fail -hard, some of them feel dizzy- no outcome.
    Hope it helps..
    Jul 08, 2008 | MSI Computers & Internet
    Hard disk is not responding while installing os
    1st plug any hard disk of urs and get a bootebel cd u can say not the xp 1 but u can find old cds like windows 98 or milenium and boot it..after sellect the cd rom support aplication..wen loaded right fdisk select yes and yes..after that delet dos or any existing partitions and restart do the sam thing again but this tim make dos partition wen ur finish restart and go in again but wen loaded on a:\ wright format C: and accept..after format is finished retstart but this time boot frome windows xp or the operation system disk u want 2 install..and folow the instruction..and if i didnt work after u do all that u go 2 ms dos and make a scandisk for c after u format u can see all comands in a:\dir , thats all and 4 the other hard drive u dont need 2 do the same just after u install widows u plug it and go 2 cotrol panell in administrative tools and select the icon that have a pc signe and after that frome the second option u select the 3 and u see ur second hard disk format it and scan it and evry thing will be just fine........
    Feb 04, 2008 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
    Format a gateway hardrive
    insert a windows cd...boot from it and format the drive.
    Nov 19, 2007 | Microsoft Windows 98 for PC
    Can u help me?
    You may insert the Windows XP CD and reinstall Windows XP just to be sure. Follow the instructions on your screen and format the C Drive. Make sure you install all the required drivers to make everything work.
    If you are optimistic follow the following instructions:
    This will help you attempt to repair your system (and not via the Recovery Console).
    Insert the Windows XP CD and follow the instructions on your screen.
    Then after a certain point, you will be asked for three options --
    1. Install Windows
    2. Repair via Recovery Console
    3. Some other option I don't recall.
    Select the first option.
    Then again, follow the instructions on your screen and again the computer will ask you three options.
    This time select the second one -- Attempt to repair the computer (Press R).
    This should start the automated repair process. This has been observed to work most of the time, but in a few rare cases it doesn't work. So I suggest you try it if you have the patience. ;-)
    Good Luck.
    Oct 13, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
    IBM Netvista 6059 - Can't upgrade to windows XP
    Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
    Sep 04, 2007 | IBM NetVista PC Desktop
    Acer Aspire 5050-3242 Notebook Logo
    57 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
