Question about JBL Spear Gun, "38 Special Woody" Magnum Speargun
The plastic tip of my gun where the rubber slings are held is broke. Do you sell that part? what is the name of it?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 14 Answers
It's called the Muzzle... the part is around $22. I did a quick search and found some here: http://www.bluewaterhunter.com/shopsite_sc/store/html/shop_gunaccessories.html
But your local dive shop that carries JBL probably has them as well.
Posted on Aug 10, 2009
What are the difference between airsoft guns and traditional guns?
Airsoft guns refer to replica firearms primarily used in airsoft that are capable of firing plastic pellets through a piston driven by compressed gas, spring and electricity or battery. This type of gun is non-lethal and capable of offering more realistic replicas. You can upgrade your airsoft guns with cheap airsoft gear too.
Sep 18, 2014 | Ics MP5A5 Airsoft Gun
How to load grease in it?
The model 1056S will accept the standard grease cartridge available at any parts store. I have to use a razor blade and cut off the metal pull tab end. Then push the cartridge into the cylinder from the top. The real trick is to guide the rubber seal into the cartridge; it can be done, I load mine this way. Use the little lock to hold off the long plunger, allow just enough to work with inorder to insert rubber seal into cartridge. Only after the rubber is in the cartridge, then screw on the bottom cap. Then release the long plunger rod. You noticed that the plunger rod will rotate out of the rubber seal assembly, rotate it so the rod can be pushed into the cylinder without pushing the rubber seals. The sping will push the rubber seal to ensure grease is mover to the top. Very powerful PSI, do not blow out the rubber cups around the zerk fittings. Good luck
Jul 05, 2014 | Alemite Lever Gun Model 1056s
I broke a plastic line that runs from the engine to a box and then to the fire wall
You can get new T fittings and rubber hose through any part store, just bring a piece of the rubber tubing and 1 of the t fittings with you so they match up the size, they can sell the hose to you by the foot so have an idea of how much you will need
Mar 26, 2013 | Cars & Trucks
Washer is stalled .takes water and drains water ok .. bur do not agetate and does not spin
need to know what kind of washer sounds like a whirlpool or kenmore if that is the case there is a coupler between the motor aned the transmission you can tip the machine back to see if part is broke, it is two plastic pieces that connect to one rubber piece either plastic will be broke or rubber will be torn
May 12, 2011 | Washing Machines
It is leaving the staples sticking up 1/2 " with
The driver blade breaks very easily on 18 and 22 ga nailers. I would suspect that the tip broke off. Easy to check. Remove the nails, connect airline and press the gun against rubber hose while holding the trigger. The gun will fire and driver will stay in the down position allowing you to check the tip. The tip should extend past the nose about 1/8 inch. When you release the trigger or pick up the gun, the driver will retract. Order parts as needed from www.toolpartsdirect.com
Apr 15, 2011 | Porter Cable Cable 18 Ga 1" Narrow Crown...
I have a 16-A WELL air soft gun that broke, i need solutions.
Its a well airsoft gun which=**** get a better airsoft gun and you wont have to deal with that ****
Mar 13, 2010 | Laser Automatic Airsoft Rifle Gun with +...
Heater hose broke off at firewall.there is a plastic connector which I can't get off. it spins but does'nt back out.how do you remove this connector?
There is a removal tool to release plastic locking tabs at back near fire wall, I had the same problem with my 01 silverado I used a 4" piece of hacksaw blade held with vice grips and cut aluminum cover and pried it apart to release, be careful not to cut heater core tube.
Feb 28, 2010 | 2001 Chevrolet Silverado
The piece of plastic that are held on by two screws for the elevation adjustment came loose . The problem is I tightened it too much and broke that piece of plastic. Was wondering if you could sant me a...
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Oct 30, 2009 | Bushnell Elite 3200 3-9x40 Matte Firefly...
What brands of nails will work in my 15ga finish nailer 1000993
Here are a few tips on buying nails for your nailer. Nails are sold in two basic categories, clip head and full round head. The clip head are lower in price and are usually taped on glued together with no spacing between them. The full round head have spacing between each nail and are held together with plastic. Some nailguns can use both types. It is important to verify the angle of your gun. To measure the exact angle use a straitedge along length of rails and a protractor at the barrel of the gun. Place the protractor on the barrel with the 90 and 0 degrees aligned with the barrel and hold the straitedge aligned with the rails and the 0 degree mark. Read the angle. You may find that your gun measures a different angle. Nails are sold from 0 to 34 degree. 34 degree is usually clip head for Paslode, Senco, Hitachi and other brands. I find that many brands of nails do not list the angle, but list the name of the gun instead. This makes it difficult for non-branded guns. Take the protractor into the store and measure the angle of the nails or place the nails on the outside of the rails to see if they align with the barrel. Shop several stores because nails vary by brand. Once you verify the perfect fit, ask for a sample strip to try in your gun. When you identify the angle and type, use this information to shop for price. Most nails are imported from around the world, however there are nails still produced in the US costing more. Home Depot and Lowes do not carry a full range of nails.
=Google the internet for more info on nails such as www.nailzone.com. They sell a 33 degree nail that may fit your gun. Good luck and email me or post again with more questions.
w
Jan 19, 2009 | Northern Industrial Tools Air Tools &...
JBL Spear Gun, "38 Special Woody" Magnum Speargun Logo
153 people viewed this question
Top JBL Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a JBL Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
