Question about Dryers
I have a Leonard 508 clothes dryer and I am replacing the main belt for the drum. The tensioning wheel/bracket together with spring has also come off. Do you have a diagram of how it is to be reattached in the dryer with the new belt? I am not sure of the exact configuration.
  • Craig Butler
    Craig Butler May 11, 2010
    hope this is helpful
  • Craig Butler
    hope this helps.....
    President:
  • 1,714 Answers
Posted on Jul 20, 2009
How do you install the belt on clothes dryer
usually goes in a 'Z' type shape. around drum to around motor drive, then push spring loaded wheel towards motor drive and hook belt over that for tension. of course this is all done by feel for the most part because you cannot see well while trying to put it on. good luck
Mar 15, 2015 | Dryers
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Jun 20, 2008 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
I have a Fridgidaire Model FEQ1442ES that makes a loud thumping noise when the drum is spinning. The belt tension wheel is not damaged and the rear shaft bearing seems fine when I manually turn it with...
Hi, Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Also dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Apr 11, 2010 | Frigidaire Electric Dryer
Dryer has a squeaking noise. does it need to be
Change the belt and check all of the bearings for play. If any have too much slack replace them.
Jun 23, 2009 | Dryers
Clothes Dryer belt assembly
yes,make sure you have the ribbed side on the drum-mike
Nov 04, 2008 | GE DCVH515EF Electric Dryer
How to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Aug 29, 2008 | Dryers
Belt and pully
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Jul 11, 2008 | Whirlpool Dryers
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Dryers Logo
130 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
