The problem may be the wiring /cables from the base unit that runs up inside the machine to the motor has got damaged and is shorting out against the casing or shorting out between cables
especially at the hinge point , you will need to gain access to inner wiring/ to repair, good luck PS it may only need a bit of insulation tape around cables , good luck
