Question about CTG Tv To Pc Converter
How to connect a Pc to tv converter ITV-900 to an Accer Aspire 1
My husband and I are trying to connect our Accer Aspire 1 laptop, to our RCA big screen tv to watch tv shows. We purchased the PC to TV converter ITV-900, but don't understand how to hook it up and project the picture and sound onto the tv... Help, please..
Also, once projected onto the tv how do you make sure the size is scale?
Thanks in advance
    Problem Solver:
  • 14 Answers
Here you have a video tutorial:
Posted on Jul 24, 2009
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
Can i connect my acer aspire 4730z to my television so i can watch dvds
Yes of course.
First of all you will need to identify the available input ports on your TV. An RCA port is generally standard nowadays and it consists of a red, a white and yellow coloured reception ports (the colours may differ between tvs, i.e black instead of red). The red and white are for stero sound and the yellow is for video.
Modern TV systems also have a VGA adapter which is small flat port like the ones on a computer screen. This is usually blue.
A third option is an S-Video port, which is round in shape.
To connect your laptop using the RCA port, you will need an S-Video to RCA converter. You connect the S-Video to the port on your latptop, and through the converter to the RCA yellow port on your TV. For sound you will use another cable that connects to the headphone jack on your laptop and then splits to a white and a red cable to connect to your TV.
If you have VGA port on your TV, then connect the VGA port on your laptop to the VGA port on your TV. No converters needed. For sound you will use the same approach as above.
To use the third option you will need to have an s-video out port on your laptop and you will connect it directly to your TV s-video port. For sound, again you will use the approach as the rca solution.
Then, using your remote control, select the AV mode or depending on your TV select the PC or VGA mode.
Finally, to transfer the video from your laptop to your TV press and hold the Fn key on your laptop's keyboard and then the F7 or F9 key. (It has s small TV icon on it).
That's it!
Regards,
nicolasiac
Apr 08, 2010 | Acer Aspire 4730-4947 Notebook
How to hook my accer pc to my phillips lcd tv
You will need a s-video cable which you can use to connect the laptop and the tv.
and that should do it for you. You may have to toggle the video by pressing Fn key + F2 key to get the display on the tv.
this will do it for you.
Mar 06, 2010 | Acer Aspire 5315 Notebook
How do I connect my laptop to my TV wiyh a VGA
do you have a VGA input on the TV?
If not, you need a PC to TV converter.
Link Here:
http://www.geeks.com/details.asp?invtid=ITV-900&cat=VCD
This ITV-900 is a one piece PC to TV Converter that lets you show computer presentations, play games and watch DVDs on TV. It converts your computer's VGA signal to your TV's S-Video and video output signal!
The PC to TV converter supports up to 1024 x 768 resolutions, NTSC/PAL television system, auto fine tuning and more! This ITV-900 is compact, portable and easy to use!
Nov 26, 2009 | HP Pavilion zd8000 Notebook
ITV 900 Converter won't display correctly
If the TV is a progressive scan, you need to set your refresh rate to 60hz if it is not, it needs to be set to 30hz.
I'm assuming you are not using an LCD HDTV. This is not a recommended setup for connecting to a PC, (using a standard CRT television) as you will likely never be able to get all of the computers screen area displayed on the TV.
Apr 04, 2009 | Computers & Internet
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
I am trying to connect my PC to my TV. I have a Sharp HDTV and my PC is a Toshiba with windows XP. I have a componert video cable which is connected to the TV and PC. I have used Fn and F5 didn't work....
what model of TV was it please,
Does your computer have tv out video card installed?
For video to tv you will need a vga to tv converter,this is an external device and will work on the computers vga output straight into a vga input and give you 1 x vga out,1 x rca out, 1 x s/video out,comes supplied all prebuilt with onboard graphics solution. no extra power required runs straight of vga output.
Once the computers video output is established then set the TV up to tune into the converters output signal.
HD TV can be set up to run thru rca and components and if model is late enough shuld come equip with serial vga input for computers.Other than that HDMI seems to be the better quality of picture over rca component.Cost verses dollar really and function.
Cheap fix VGA to TV CONVERTER
Expensive Fix HDMI to HDMI
(it is posible to hdmi over cat5e)
NO COMPARISON FOR QUALITY.
Jul 10, 2008 | Acer Aspire 3680 Laptop
Connect Laptop Computer to TV
google this
ITV-900 pc to tv converter
May 18, 2008 | Televison & Video
CTG Tv To Pc Converter  Logo
584 people viewed this question
Top CTG Televison & Video Experts
Electro Med Services...
Are you a CTG Televison and Video Expert? Answer questions, earn points and help others
