Washing machine grinding
My washing machine is making some unusual noises, a kind of grinding or winding. Cant say at any particular point just when it feels like it!
sounds like the noise is coming from the bottom right hand side at the front.
Roper# ras7133kqo bought at lowes how to remove agiator there is a piece of metal under it
Posted on May 05, 2008
  • 248 Answers
Please give the model number and the brand. Model tag may be on top of console in back, when you open lid on the top center, on the left side bottom or on the right side top in back.
Posted on Nov 19, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
My washer makes a loud rubbing noise only during the wash cycle any idea what could be causing it?
Look at the pulley under the bottom center. On this model the nut often backs off and makes the pulley sit wrong which causes a kind of grinding noise.
Sep 27, 2015 | Washing Machines
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
My cabrio top loader high efficiency low water washer is making noises
sounds like water has got past the seals and into the upper bearing.if this is the case you will hear a loud roaring noise during the spin cycle.not a cheap fix!
Dec 17, 2017 | Whirlpool Washing Machines
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
Making a grinding noise in both wash and spin cycle. water is draining
Your transmission is the most likely issue. The internal gears are starting to grind. This is typical of this particular model. (manufactured by Admiral) There is a possibility that the pump pulley has come loose and is grinding on the unit's frame or pump housing itself. If this is the case, it can be fixed at a reasonable price. If it is the transmission, start shopping for a new machine. The transmission replacement is not cost effective.
Dec 29, 2010 | Maytag Performa PAV3200
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Tecnik tlk 925 washing machine not spinning
sounds to me like your carbon brushes have worn down if they wear down too far they will hit the metal casing that explains the grinding noise
Aug 08, 2008 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
200 people viewed this question
Top Washing Machines Experts
