Question about Sony PlayStation 2 (PS2) Console
Ps2 not reading discs
Having played 1 game for a while i decided to change discs then it wouldnt read other disc
Re: ps2 not reading discs
I have a playstation 2 the original game cd that was given along with the playstation would play but now it does not it open but when you go to select the goes off. Two earlier gaming cds would play but not they don't play.
Posted on Mar 09, 2009
  • 4,102 Answers
Does it still read the disk you was playing or not if it dont then you could buy a lense cleaner put this into you ps2 and then after it has cleaned the lense try your games again you can buy these really cheap and they are just a disk with little brushes onn that cleans the lense in anything that takes disks if this dont solve the problem and the ps2 dont play any disk at all then the laser will need replacing you can replace it yourself but it will need to be recalibrated witch is something a pro must do as not doing this will stop it reading any disk but you only get this prob if you buy new laser you can get second hand ones but you never no if they are working or not hope this is some help to you
Posted on Nov 19, 2007
0 characters
3 Points
Disc not spinning
the laser lens may be faulting. bottom line the system is not going to work for now.
Jan 02, 2010 | Sony PlayStation 2 (PS2) Console
Wont read discs
Downloadable games are not playable on PS2. If you're trying to play pirated games that you've downloaded from the Internet you're going to need to have your PS2 hardware modded to play DVD-Rs, which is expensive, dangerous, and illegal.
Jan 03, 2009 | Nintendo Wii Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 slim problems reading disc
After countless hours of tying to figure this out I went to the basics. This ps2 slim has 3 sensors and after all sensors are the key to making the machine work properly. After testing everything known to man I decided to go around the sensors by taping them all down. Low and behold when I cranked the ps2 slim up the disc now reads and plays perfectly.
Aug 27, 2008 | Sony PlayStation 2 Slimline Console
Disc read error
get it repaired. obviously the drive is not spinning correctly for ps2 disc. so take it to a shop ask for a quote to repair.
most ps2 are about $99.00USD
Jun 07, 2008 | Sony PlayStation 2 (PS2) Console
Please.. help me... my ps2 slimine is comepletely ruined..
Since you "smashed" which made things much worse (been there, done that). It was probrably fixable but now that it scratches I can only assume that the lens (laser) is scratched and damaged "beyond repair". The only suggestion I have, if you really want to fix it is to replace the lens and probrably the disc tray too. Fot the trouble it's worth too fix and the fact that there is no guarantee that it will even work after you fix it, your best bet is too buy a new one or at least a refurbished one.
Jan 06, 2008 | Sony PlayStation 2 Slimline Console
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Problem of ps2 console
Hi Faizy,
It should play Cd, Cdr, and DVD as well.  If it will play PS2 and ps1, it should have not problem playing the other three.  If your discs are dirty that was cause it not to read.  If its more can you please expand on what is happening.
Oct 11, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Loading & Playing
change you'r ps2 lence ribon.-goodguy electronics-sri lanka -094785180737-
Aug 20, 2007 | Sony PlayStation 2 (PS2) Console
Unable to read new games but can read old, used games???
Things like this are usually caused by overlooked manufacturing discrepancies. It may be best to contact Sony with your system's model info, serial number, and date of manufacture. They may be able to help you under warranty. Greg Holiday
Jun 09, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
403 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
