Question about Danby DPAC8399 Air Conditioner
Need window adapter for exhaust hose - Danby DPAC8399 Air Conditioner
Do I need a kit or adapter to have the exhaust go to the outside instead of back inside?
Yes, they are sold at home improvement stores and consist of a hose and a vent. They require a hole be cut in the wall for the vent tube to exhaust outside.
Jul 04, 2017 | Dryers
Where can I go buy at a store near me, a hose for the Artic King portable AC, the hose that goes from the back of the unit to the window? HELP! Ive been everywhere???
hi,
the air output circumference is a standard flexible dryer exhaust vent line and the water drip line circumference is washing machine drain line. take a picture of the hose ends and take it to the home depot or lowes. cut up a cardboard box and use some duct tape to finish where the window adapter goes..
jm
Jul 04, 2017 | The Computers & Internet
What causes the exhaust hose to get hot on a windchaser portable AC
make sure its not obstructed, then wrap it up with a towel or other insulative material. it heats up because the heat exhausts through that hose out the window.
Jun 28, 2014 | Windchaser PAC9 Air Conditioner
Amcor KF9000E portable air conditioner manual
My amcor kf9000e has stopped blowing cool air. What could be wrong with it?
May 18, 2012 | Amcor AF9000E Portable Air Conditioner
Hello, I need the hose to drain water outside that fits the fridgidair portable air conditioner #FAPO9EP1Z1. Is there another small tube or is there any other hoses or vents that I need? I don't see...
impreston - with out the following parts , you really don't have "just the air conditioner."
1- Flexible Exhaust Hose
2- Hose Adapters
1- Sliding Window Kit
1-Foam Window Seal
1-Remote Control
The drain hose is something you supply. A garden hose, no longer than 5 feet will do if you want it to be a continusos drain, rather than drain into the water collectiong bucket. But, without the first 4 items lister above, you won't be able to operate the unit.
Here is a link that may be of some help to you, since you don't have an Owner's Manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020252a0373en.pdf
You will beed to contact Frigidaire (1 -800-374-4432 ) for the parts you're missing.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire FAP094P1Z Portable Air...
Hi I've just purchased a used HPRD12XC5 portable air conditioner. It did not come with Air Intake/Outlet hoses, exhaust adapter or window slider kit. Is there somewhere I can buy these? Thanks -...
Harry. if you purchased it from a brick and mortar store, rather than online. Return it to the store for replacement. Or you can get it from Haier under warranty, with your Proof of Purchase. It's more to it than just the air intake and the exhaust hoses.
You can contact Haier Customer Support at 877-337-3639.
Jun 02, 2011 | Haier HPRD12XC5 Portable Air Conditioner
Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Jul 09, 2010 | Amana Heating & Cooling
Missing exhaust kit. Need window adapter, hose and connector/adapter for back of unit hot air exhaust port. NMPEB08F2A Rev B made by Maytag / Fedders
Try duct tape , pvc pipping and cardboard, Tape the pipe to the back of the ac and them use a cardboard piece with a whole cut out for the pvc pipe in the window ,coat the cardboard with several layers of tape inside and out..It should work for awhile..Or call the Maytag/Fedders maybe they will send it to you free...
Jun 12, 2010 | Maytag NMPEB08F2A Air Conditioner
Danby DPAC8399 Air Conditioner Logo
126 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
