Question about Maytag Neptune MDE5500AY Electric Dryer
Wont start up.
After dryer starts and runs one load it will not start up, when you push button a loud humming noise and overheating smell results.(like wiring).
  • 1 more comment
  • Anonymous Nov 29, 2007
    mde9306ayw. Dryer will come on for a few seconds then shut off. I took the drum out and turned the dryer on and actually watched it shut off. I witnessed the smoke coming from the motor. I'll try cleaning it to see if that helps. If not, I'll replace it. I worked on this long enough....
  • Anonymous Mar 17, 2014
    When start button is pushed dryer makes loud humming noise but no action begins at all.
  • Anonymous Mar 29, 2014
    there's a loud humming noise when unit is turned on, then PAU appears on screen
  • 447 Answers
Sounds like the motor is failing. The main cause of failure is overheating due to clooged venting. Is the dryer taking more than 60 mins to dry?? If so then the vent is clogged. Its likely too that the motor is covered with lint and not being able to properly dissipate its own heat, you could clean it and see if it helps but usually once they are shutting down overheated (the burning smell is the motors' internal windings being very hot) they need replacement.
Posted on Nov 19, 2007
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Burning smell, Loud noise when start button and doesn't turn on
Belt, and skid plates very easy to change and not much money
Aug 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer hums but will not start
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Nov 04, 2007 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
390 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
