Question about LG RUMOR Cellular Phone
Can't pair device
I bought a bluetooth and have followed the instructions on how to pair the devices but no such luck. It just says no bluetooth device found. Followed everything but resetting the phone, which I don't really want to do as I'll loose my pics and info.
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
Cant connect to my laptop
Assuming your laptop is Bluetooth compatible, make sure all other Bluetooth devices are out of the area so there is no interference. As each computer may search for the headset differently there is no generic guide as to how to pair up the two devices together. Carefully follow the instructions of the computer for pairing or call Plantronics at 800-544-4660 x5538.
Good Luck from Headsets Direct!
Jul 20, 2011 | Plantronics Explorer 240 Bluetooth Headset
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a LG GT 365 phone. I bought a plantronics 240 series bluetooth device. The pairing code 0000 suggested in the instructions will not work. Any suggestions?
By default, Bluetooth technology is using the codes 000 or 1234 in pairing a device.
You may try to use 1234 and see if that will help.
You may give me an update regarding this.
Thank you and good luck!
Jun 13, 2010 | LG Neon GT365 Cell Phone
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
I need a instruction maual for a itrax bluetooth device
Pairing With A Bluetooth Enabled Cell Phone
1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
(1 metre).
2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
follow the manufacturer's instructions for that device.
4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
3 seconds.
Nov 24, 2008 | Cell Phones
Blue tooth device pairing code
open bluetooth and search for new device,when you find new device you can configure it so as no code is required and pair auto
Oct 18, 2007 | Magellan RoadMate 6000T Bluetooth GPS...
Connecting JABRA BLUETOOTH to MY SIDEKICK 3
Use your Bluetooth wireless headset or car speaker to make and receive calls: 1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible". 2. From your Sidekick, go to the Phone application. 3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.) 4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE . 5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name. 6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
Aug 15, 2007 | Jabra BT800 Consumer Headset
LG RUMOR Cellular Phone Logo
81 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
