Question about GPS
The power plug on the gps unit is pushed inside so therefore we cannot use it
    Brigadier General:
  • 4,090 Answers
Well the cost is high IF it is even a repairable brand. It requires a new motherboard and is usually more costly to repair than nbuying a replacement
Posted on Jul 22, 2009
When plugged into cig lighter in the car, with the car in-motion therefore unit on automatically, an icon appears in the middle of the screen (it's a picture of an sd card with a white "x" inside a red...
try it with out the sd card and see if it will work the card might have to much space some gps are limited on how big of a sd card they can read
Feb 25, 2015 | GPS
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Our magellan keeps turning off. the plug seem loose. could it be the cord or is it the battery and can it be changed
Check your power cord. You may be losing power at the plug. When plugged in it may be losing contact with the recepticle. The power indicator light initially comes on but, breaks contact and therefore stops charging the unit. If this is the case you can sometimes plug into an adapter and get a tighter fit.
Apr 25, 2011 | Magellan Roadmate 1200 Car GPS Receiver
Garmin GPS not switching on
If the reset described by justaskjoe doesn't help, then check the power cord. There's a fuse inside the power plug, held in by a screw ring which is notorious for coming loose. Make sure the fuse and spring are in place and the ring is screwed on firmly. My daughter's C340 stopped working because that ring came loose and the fuse fell out. Also remove the unit from its mounting cradle and snap it back in to ensure good contact.
Oct 10, 2009 | Garmin StreetPilot c340 GPS Receiver
Fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Jul 07, 2009 | 2001 Saturn S-Series
Problems with Magellan Maestro? 4040 GPS power connection
Wow if you opened the unit Magellan can tell. If your unit was under warranty You might have talked them into a repair (if your very very very persistent with you can get thin done , eventually ) but now you talk to them to see what they can do but it may be cheaper to go get another unit
Jan 12, 2009 | Magellan Maestro 4040 GPS Receiver
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Dec 17, 2008 | Magellan Maestro 4040 GPS Receiver
Battery question
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Garmin 200w does not hold charge
Hello Jeffery81,
Sounds like either a bad charger or a bad rechargeable battery pack inside of the GPS. If the unit doesn't remain powered up even when it is plugged into the charger, my guess is that the charger is the problem. Do you have an alternate way to charge the GPS? Like a 12 volt vehicle power cord or a USB cable to connect it to your computer? If so, try charging the GPS using that alternate method. If the item charges and functions normally, you will know for sure that the problem lies with the charger. If not, then the problem is either the battery pack inside the GPS or some other part of the unit's charging circuitry. In that case, you should contact Garmin technical support for additional assistance.
Best Regards,
Ken
"Go Ahead. Use Us."
May 19, 2008 | Garmin nuvi 200W GPS
GPS Logo
21 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
