Question about APC Automatic Transfer Switch (AP7701) Tablet PC
I need the manual for a "Kohler 30 - 800 Amp Series S38 Automatic Transfer Switch". This is Kohler part # K-168341 - 0104, 04CS, 23 GB, 24E, 295131 Serial # K 20172 Volts 208 Amps 104 Phase 3 Wires 4 Hertz 60 I want to install it on my 3-phase generator
I have the panasonic Sc999bt tablet. I bought a 16 gb micro sd card, when i try to download anything,it says internal storage full. Please help
Hi. Ok you're tablet has 8 GB of memory & 1 GB of RAM ::: u can delete data u don't use this will free up some memory :try to transfer you're movies & data to you're SD card :::::buy a 32 GB SD card if u need it .cheers
Apr 06, 2018 | Panasonic Tablets & eReaders
After I put a new memory card in my tablet what do I do to get the tablet to not say not enough room?
You need to manually transfer memory content to the SD card, things like files and photo's for starters. This is not an automatic process.
Jan 27, 2017 | Tablets & eReaders
Android 41 manual
here is tech support for Your device https://ematic.us/support
Jul 20, 2014 | Ematic Genesis Prime 4 GB Tablet - 7" -...
How do I get my apps from my iPhone & iPad to my iPad mini
For apps you can:
If you only want some of your apps, just go to the app store, purchased and select the apps you want. You can download for free on the new device as long on the same iTunes acct.
For all apps, turn on app share under Settings, iTunes & App Stores, turn on Automatic Downloads for Apps. Turn this on, on both iOS devices you want to have the same set of apps on
For photos, turn on iCloud Photo Stream under, Settings, iCloud.
Jan 12, 2013 | Tablets & eReaders
I have lost my instructional mnual for acer laptop aspire 5551 series and i have checked through the manuals on the website and it is not on the list. what can i do to get another manual to use. thank you....
Please check these links or post your query;
www.gadgetsmanual.com/?aspire-5920-series-users-guide.html
www.retrevo.com/support/?Acer-5551-Laptops-manual/id/23701dj298/t/?2
Sep 27, 2010 | Acer Tablets & eReaders
Need circuit diagram for Kohler ATS part # K163341-800
Do you know the part number on the board. Kohler used numbers written with permanent marker on their controls boards. They usually started with a letter like A or B.
You might have a * 297373 or *297375. They usually had a big orange relay that stuck up in the middle.
The filter capacitors would always dry out over time and relays wouldn't energize correctly.
Depending on the board we might have a drawing.
We fix some of the older style. Check out our website: www. flightsystems.com. You'll find contact info. For fast response call in and be prepared with any board numbers you might have found!
Sep 02, 2009 | APC Automatic Transfer Switch (AP7701)...
APC Automatic Transfer Switch (AP7701) Tablet PC Logo
193 people viewed this question
Top APC Tablets & eReaders Experts
Are you an APC Tablet and eReader Expert? Answer questions, earn points and help others
