Question about Lexmark X6575 All-In-One InkJet Printer
I want to reset the printer to factory settings
I don't just want to remove it from my computer... I actually want to completely reset the firmware on the printer. Anyone know how?
  • 4,655 Answers
You will need to remove it from add or remove programs and then reinstall. That is the only way to reset it. Make sure you go to Lexmark and download the current software for your model first. Save to desk top. And after restart the click on the new software and follow the instructions. Sea Breeze
Posted on Jul 20, 2009
Reset the firmware on a Epson xp-830 all in one printer I upgraded and not printer is not recognizing my ink cartridges
That is very unusual, however you may try to remove the ink carts completely, shut down the printer and let it rest a few minutes. (use new original cartridges) replace in the carriage compartment, turn it on and it should start doing a reset (head cleaning/alignment/etc.) and a factory adjustment. The new updated firmware may be set to recognize original Epson ink carts and if you have Non-Epson Carts installed, it may by default, inform you that the ink is missing. You are allowed by LAW to use any cartridges of your choice. Turn the printer on to do a full rest and it should work. If not, you will have to contact the manufactures technical support team.
Jan 12, 2018 | Epson Office Equipment & Supplies
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Wireless was connecting without issue.. used wpa encryption (passkey), mutiple computers connected well. router had orginal firmware 1.x on it so downloaded firmware from this website, made sure it was...
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Solution for your problem you can still find at this adress.
Well, its noticeable that a lot of people complain about exactly that type of router "Linksys WRT160N Wireless Router". There is definitely problem with firmware upgrade, so I suggest you to press and hold reset button for 30 sec, to put back your x1 firmware, or if that doesn't help, contact your Linksys WRT160N Wireless Router contractor and/or your ISP, and ask them to downgrade your Router. Just to notify, encryption can't defect your connection at all, since all ports on router are always opened if wired for your host pc's :)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Linksys WRT160N Wireless Router
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Instructions
Complete Reset
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
Epson RX680 Printer - How do I reset the firmware to defaults?
you will need the adjustment program to be able to reset your printer to the factory setting.. and it's really not recomm to reset the firmware as you risk of damaging the unit further.
what about the panel light.. how does they blink when the moment you switch it on?
Jun 08, 2010 | Epson Stylus Photo RX680 Printer
Magiccolor 2450 factory reset password
Here is a PDF copy of the Reference Guide, if you don't have it...
DOWNLOAD HERE (Left Click to read online, Right Click to save on PC)
Password on page 120
Factory Reset on page 133
Nov 29, 2008 | Konica Minolta Magicolor 2450 Printer
Factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
Factory default
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Lexmark X6575 All-In-One InkJet Printer Logo
266 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
