Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Not drying At the end of the cleaning cycle the dishes are completely wet.
  • 1 more comment
  • Merry Johnson
    Merry Johnson Jan 21, 2008
    I have the same problem. from the first time I used my LG dishwasher the dishes don't dry. My hot water is well over 120 degrees.  Does the machine use only the hot water? If it does, then my water should be hot enough. But the dishes are wet.
  • Wet in Tx Mar 28, 2008
    I have the same problem it dried good for a few months now has stopped. I have rinse aid in as they have directed but still to no avail, wet dishes.
  • Anonymous Mar 12, 2014
    the dishes are not dry at the end of the cycle saphire glow
  • 210 Answers
Try using the sanitary rinse as the heater only comes on during the wash and then again in the sanitary rinse.
Sgt 48
Posted on Jun 07, 2008
  • 248 Answers
These dishwashers have no heater for drying dishes. It has a fan to circulate warm air. It is very important that your water temp is at least 120 degrees. It is the combination of hot water and air circulating that dries dishes.
Posted on Nov 19, 2007
Runs through cycle, but dishes and glasses do not dry, they are soaking wet.
10 Tips to Help the Dishwasher Run Better - Cleaning Tips ...
Apartment Therapy's The KitchnFeb 24, 2014 - Well, we're here to help, with 10 tips for making your dishwasher run its best. ... loading up to help reduce particles stuck on dishes once the cycle is over. ...water to flash dry and not roll off your dishes, taking the ends of the dirty bits with it..... but can lead to damage, particularly of any glasses you put in the ...
[PDF]Dishwashers - Frequently Asked Questions ... - Bosch
this cycle the dishwasher dries the dishes. 3. ... dishes. During this time, you do notneed to be around the dishwasher as it ... Does it also dry the dishes after the wash?... You can put utensils that are made out of steel, ceramic, glass, plastic which is ...No, the dishwasher runs the whole washing programme automatically.
Why is My Dishwasher Not Drying the Dishes? ' Dr ...
Dec 03, 2015 | Dishwashers
Why are dishes wet when cycle completed?
The appliance repair man attempted to solve all problems by replacing the control board. He may have overlooked a defective heater for drying the dishes.
Sep 03, 2015 | Dishwashers
Dishes still wet upon end of cycle
Check if the heater is working. This can be done by checking if the dishwasher has steam and dishes are warm when cycle is complete. Also check if the Rinse aid has not finished. Make sure the Rinse aid dosage is not at too low.
Jul 31, 2014 | Electrolux Dishwashers
The dish washing powder does not wash out completely unless the machine is set to heavy duty only. we will often open the machine at the end of a wash cycle and see the soap powder all wet and soft but not...
Seems to be problem with spray arm pressure. Check the spray
arm jet nozzles.
Check the incoming water flow to the machine. clean the strainer fitted at the washing machine end connection.
Being in the extended warranty, take the help from
the service provider.
Aug 31, 2010 | Dishwashers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Once the cycle is complete (rinse, drying, end) the dishes are clean but not dry.
#1 plastic dishes cups etc will rarely completely dry
check your heater, check for continuity on the heater it should ohm out.
does the heater get hot?
are you running hot water at the sink before pushing the start button?
are you using a rinse agent such as jet dry?
Sep 03, 2009 | Miele G892SC SS Dishwasher
My dishes still come out do i set the washer to dry the dishes
there should be a setting or a button to turn the heat dry on and off, if it is on and dishes are not drying then the next time you do a load of dishes pay attention to the cycles, after the rinse cycle is complete the heat should come on. if not you could have either a bad heating coil or a bad relay.
Aug 20, 2009 | Kenmore Dishwashers
Wet dishes
If the dry cycle has a problem, check these:
Heating element
Drying fan
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher stopped drying dishes at end of cycle
check the heating elemt circut and make sure that heated dry has been selected it the machine allows to need the model of the machine for more help
May 05, 2008 | Dishwashers
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
385 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
