Question about GE GSL25JFPBS Side by Side Refrigerator
New filter but now no water
I just installed a new water filter for the first time and it worked fine for a couple of hours. Now - the water despenser won't work at all??
If you take the kick plate off below the doors, on the left hand side below the freezer door youll see a hose conection. disconect that conection and press the water dispenser lever. if water comes out then the line running into the freezer door is frozen. use a hair dryer to warm up the inside of the door behind the dispener. it takes about 20 to 30 min but once thawed the dispenser will work again
Posted on Nov 19, 2007
Water wil not despense
Could be a few things. Either the water filter is not in correctly. The water line could be frozen in the door or in the cold water reservoir that is in the refrigerator section behind the bottom drawers. You can tell if it is frozen in the door if it is a SxS by unhooking the water line before it goes into the bottom of the freezer door. Just unhook it at the pressure fitting and then try to get water. If it is frozen in the door then water will come out of the unhooked line when you try to get water. Also could be a bad water valve.
Oct 19, 2014 | Whirlpool Refrigerators
I have a 1992 Pontiac Sunbird that will not start
Needs to have at least 3o lbs of fuel pressure,may need to rent
a gauge from your local parts house.
Plus make sure all the ground wires are attached (bell housing
bolt is where the ECM ground is,I think)
Mar 19, 2013 | 1992 Pontiac Sunbird
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
Dec 08, 2010 | Whirlpool Refrigerators
My GE GSS25VFPAWW side by side refrig. wil not despense water.
I turned off the unit for an hour with the door open and the ciller tubes thawed. the water started wotking again.
Dec 26, 2009 | GE GSS25VFPWW Side by Side Refrigerator
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
My icemaker works fine, but does not dispense water from the door
Had same problem, my despenser water line was froze in the door. Here is the steps I went through to fix.
Dec 02, 2008 | GE GSS25LGM Side by Side Refrigerator
Water despenser
hi there,
check to see if you have a leak in the water line. the line runs from the wall to the icemaker. do you have any leaks on the inside of the door? any frost build up? im assuming that you have a side by side fridge with an icemaker.
Oct 11, 2008 | Refrigerators
Water despenser not working.
check the correct fix of water filter i think compraser is not work
Sep 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Icemaker not getting water
water despenser is working fine,but ice maker is not working
2 yr old maytag french door refridgerator
Dec 27, 2006 | KitchenAid KSCS25FKSS Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
125 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
