Whenever I turn my tv on a blank screen appears, and it says "weak signal" whenever i try changing the channel.
  • 2,200 Answers
This problem is caused by poor signal reception and there are several possible causes for this.
1) First check that there is no problem with the cables connecting your cable box or antenna to your television. The connectors should be fully engaged into the units and the connectors on the cable themselves must have good contact to the wire within the cabling. It is also important to check that connectors have not been shorted by the inner core of the cable coming into contact with the outer sheathing wire on the coaxial cable.
2) If you use a powered signal booster make sure that it is fully operational and properly connected.
3) If you are receiving terrestrial signals you may have a problem with your antenna being waterlogged or having shifted on its axis causing a loss of signal alignment. If your receive satelite broadcasts your dish may require realignment.
4) It may help to retune your television by entering the menu and selecting the automatic tuning function.
5) You may be suffering from weak or compromised signal in your area and this will require a signal booster to be installed.
6) Finally the tuner on your television may be faulty and if this is the case it will require service attention.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 20, 2009
TV screen screen's blank but it's on stand by. whenever using a remote it does not show anything.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
I have acer aspire 4520. Whenever i turned on the laptop, the screen will go blank. The power button is still on which means that it wasn't the motherboard problem. Sometimes, the screen turn on but after...
before you change the screen, try to plug the laptop into a monitor or any flat screen tv. are you able to view the image on the tv? if so, your screen is broken.if not, there is something wrong with your laptop and you may want to consider a system restore.
Feb 28, 2011 | Acer Aspire 4520-5582 Notebook
I changed my tv and in new tv whenever i try to
You need to try and change you video audio settings for that tv,on your ps3.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
My Polaroid FLM-3232 does not display over air HDTV channels
There is no such thing as a 'digital antenna;' any antenna with sufficient gain and bandwidth will receive whatever signals there are available.
You may have to change the input source via your set's menu so it is looking at the antenna input; it may be set to cable currently.
Feb 03, 2010 | Polaroid FLM-3232 Television
Missing or weak signal
try a outdoor antenna on the roof for digital signal use.also the main digital PCB is defective which has the tuner on it if the antenna does not work.you may try taking the
tv to a friends house and see if the tv works better.
Sep 04, 2009 | JVC LT37X787 37 in. HDTV LCD Television
Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Apr 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
At random a black retangular box appears on the screen
Go into the TV's closed-caption settings and turn off captioning. You'll find it's set for "text" mode right now. What's happening is that in text mode, the set blanks out the part of the screen where the text will go but there isn't any. On channels or programs where captions aren't being broadcast you don't see anything. With the captions turned off the box will go away.
Apr 10, 2009 | Toshiba 20AF41 20" TV
Screen
try unplugging th tv for 30 second and then turn it back on that should work =]]
Mar 26, 2008 | Vizio L32 32 in. LCD HDTV
ZENITH TV, no picture
Sounds like the vertical output IC causing the CRTs to blank you would still have audio and on screen display. Try resoldering the vertical output IC.Thats a common problem
Mar 19, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
