Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rainbow effect, no picture. T.V. was turned off with no problems, but when it was turned back on there was bent lines , no picture.
    Novelist:
  • 123 Answers
Bent lines?????????????
Posted on Jul 23, 2009
Strange rainbow.reenish type effect
Did you notice any better picture when you play a movie on a DVD player or using a flashdrive on this TV? Is the picture quality better? Or is it the same? Try to check another cable connection or try to play TV channel thru internet. The last option in this case is to show a TV mechanic for he would better understand which part to order.
Jan 20, 2014 | LG 60PZ550 3D Plasma TV
Has a double picture and looks rainbow
A double pcture with two different colours??? more seriousely the rainbow effect could be of an appature grill un hooked in one of the three tubes (THIS IS DANGEROUS IT COULD IMPLODE) you should have a proffessional looke at it and you should NOT USE OR MOVE the TV until then.
Jan 04, 2011 | Sony KP-53V75 53" Rear Projection...
My son was bouncing a small ball against the screen and then it went to looking like a rainbow. Would this be the picture tube?
He may have caused some type of damage to the picture tube, but usually rainbow effects happen when magnets are present. Perhaps the ball became charged with a large amount of static, which then discharged across the tube, damaging the controlling circuits.
Jun 03, 2010 | Toshiba 36A43 36" TV
Has rainbow lines on tv screen
shadow mask is warped. tv might have been dropped. crt is bad(picture tube). try deguassing it. if you dont know what that is take it to your local service center. the rainbow effect is a magnetic field of some sort. try unplugging and move to a different location. could be a speaker too close to tv.
Nov 12, 2009 | RCA F36650 36" TV
Colourful picture
Discoloration of this sort is caused by magnetism. All CRT TVs (like yours) have a de-gaussing coil around the picture tube that de-magnetizes the screen (more specifically the shadow mask) every time you turn it on. It is likely that the circuit that controls this coil is at fault. There is probably a cold solder joint where it connects to the main circuit board.
The other scenario is that someone (small child generally) has run a magnetic object very near to the screen, magnetizing the shadow mask (inside the picture tube) and causing a rainbow effect. This is less likely if the rainbow effect is a nice even circular shape. Generally if it's been magnetized by a magnet as described the discolored areas will appear blotchy.
In short, if you have some electronics skills, get in there with your soldering iron and touch up the connections to the de-gaussing coil. If not, find someone who does.
Oct 01, 2008 | Televison & Video
Bent picture
Not sure if you fixed your problem already. But the answer is a color convergence problem. You can try adjusting manually via the remote and if that doesn't work it is most likely the two main IC chips that control the color convergeance. It is also possible that not only the IC chips have gone bad but also there are a couple of resistors that usually burn out with the ICs as well. They will need to be replaced. This isn't something that I would attempt on your own. Typically a TV technician will charge between 300 and 400 to fix at your house.
Mar 15, 2008 | Philips 60PP9363 60" Rear Projection...
Rainbow
Rainbow effect has more to do with color wheel style and speed.
Jan 31, 2008 | LG RU-44SZ51D 44" Rear Projection...
Tv needs fixing, advice appreciated
it would intermittedly display a bowed rainbow effect and the picture would jump to that/black/back into focus. it was nothing but due to change of place due to decaussing ckt to take care of magnetic effect of earth. this morning i turned it on with a black screen. It has audio but no video. your problem it sounds me that it is due to loose contact or loose connector or due to video ckt. as you said that sudio is ok. if you are not tech person call skilled tech to fix it .it is not a major problem. hope this will help you please let me know what happened.
Sep 29, 2007 | Toshiba TP50F60/61 TV
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
178 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
