Question about Kenwood KDC-MP2035 CD Player
Not Holding the Memory
I just recently was given my Kenwood KDC-MP2035 CD Player for my birthday and it was installed. The first time I turned it on, I set everything, clock, bass, radio stations. Then, when I got into my car the second time, everything was blank. This occured with the cd-player i had in my car before, and I was wondering if it's a problem with the wires.
  • bryanmoore Jan 08, 2008
    I connected the yellow wire to my cigarette lighter hot wire and now my cd player stays on even when my key is out of the ignition. The cd player stays on all the time. If I power it off when I'm not using it will that suck my battery life?
  • mustbedeb Mar 03, 2009
    i have just put in a beat cd sd mp3 player in my car but the radio isnt storing the stations when i turn it of .. ther is only to sockets at the back of the unit and they are both used
  • 626 Answers
Sounds like a wiring problem.
There is a YELLOW wire that should be connected to a constant +12 volt supply when the vehicle is off. This retains the settings.
Check the connections and see if thats the problem.
Please RATE my solution at the bottom.
Best of Luck.
Posted on Nov 19, 2007
Kenwood deck kdc-mp2035 im not sure about blue wire or yellow or red
Normally on Kenwood, blue is not usually used, it's for power antennae, make sure it's end is not bare though. Yellow would be to a continuous 12volt+, for memory. Red goes to accessory, (+12volt) where only power when key on, or in accessory position.
Oct 15, 2011 | Kenwood KDC-MP2035 CD Player
I need unlock code for my kdc-mp2035 kenwood stereo
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Mar 27, 2010 | Kenwood KDC-MP2035 CD Player
Kenwood kdc mp2035 locked need a code to unklock
i no a trick for this ,put it in the freezer over night and it will crack the code crystle,yes i said put it in the freezer
Dec 27, 2009 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-MP2035 cd player has power and everything functions but there is no sound. The 10A fuse in the unit is good.
make sure that the power output is enabled. this will turn on you internal amp. I have the same unit and I fouund this to be a problem. If this does not work your out put amps might be fried. good luck.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 07, 2009 | Kenwood KDC-MP2035 CD Player
Need security code for mp2035 kenwood cd car tuner.
BUENAS NOCHES
TENGO EL EQUIPO PERO PERDI EL MANUAL Y NO HE PODIDO CUADRAR EL RELOJ Y PROGRAMAR OTRAS EMISORAS
MIL GRACIAS
Oct 01, 2009 | Kenwood KDC-MP2035 CD Player
Mp2035 cd player will not turn on.
My hunch is that the fuses blew. When you cut all three at once you shorted the battery to ground and most likely blew out the fuses. Check the fuses and let me know. That is my best guess. Good luck
-Andrew Hawkins
Jun 10, 2008 | Kenwood KDC-MP2035 CD Player
POWER TURNS OFF AND ON
do u have a subwoofer or any thing hooked up to it
Jan 02, 2008 | Kenwood KDC-MP2035 CD Player
Setting the time on a Kenwood KDC-MP2035
Make sure the power is off before setting the clock (hold down the "FUNC" button until nothing shows but the time). Then Hold down one of the buttons on the right side for like 3 seconds until the time starts blinking. I can't remember which button it is as I don't have the unit in front of me right now. Use the track buttons to adjust the time. Hope this helps!
Dec 21, 2007 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-MP2035 CD Player Logo
335 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
