Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 42 inch craftmas mower and the fluid is leaking from the hydrastatic area, can I replace it with transmission fluid.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
If you transaxle is leaking badly adding oil may not help long term,if you remove the back hitch plate there is a allen wrench plug or a rubber vent hose, you can add oil there,measure down from the top of transaxle and fill to within 1.5 inch of the top,always allow 1.5 in of air space in top to allow for expansion. Add amsoil or mobil 1 synthetic motor oil 15w-50 or 20w-50. Do not use transmission fluid or hydraulic oil.
Posted on Jul 30, 2009
Why doesnt my MTD 42" lawn tractor move but it will start?
If the transmission is belt drive, check the belt, worn/oily? If you have a hydrastat tranny, make sure that the bypass plunger is pushed in. Check that the belt goes around the tranny pulley. If still no luck, turn mower off, jack up and support the rear frame, with the real wheels hanging in the air(just an inch or two is plenty) try turning the wheels -1st, with the gear selector in "N". then 2nd, with the gear selector in "D". This should narrow the problem down a bad tranny or a sheared keyway in the axle.
Jun 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower stuck in gear
I would say you have a problem in the hydrastatic transmission itself,and that could be a number of different things and hard for you to fix yourself,it would be best to have professionally checked out.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What fluid is used for the Hydrastatic transmission on a Yamaha YT3600
best advice is to contact the dealer and ask for the type of oil you are to use.
Apr 21, 2013 | Cars & Trucks
What is the fluid type in a murry auto drive transmission
I use 30w motor oil, plug ( either rubber or steel ) is on top.
Jul 07, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Hydrastatic transmission not working right it is slow;
first check the belt tension then the fluid level if you can
Apr 10, 2012 | Garden
Leaking transmission fluid
TRANSMISSION FLUID LEAKS,CAN BE FOUND AROUND PAN GASKET.CHECK PAN GASKET,IF IT LOOKS WET AND YOU SEE FLUID DRIPPING AROUND THE EDGE OF OIL PAN, REPLACE PAN GASKET, WHILE YOU REPLACING PAN GASKET REPLACE TRANSMISSION FILTER WHILE OIL PAN OFF.IF TRANSMISSION OIL PAN NOT LEAKING, CHECK TRANSMISSION OIL COOLER LINES GOING INTO RADIATOR YOU WILL LOOSE A LOT OF FLUID THERE ALSO TORQUE SHAFT SEAL WILL CAUSE HEAVY FLUID LEAK WHILE ENGINE RUNNING CHECK OIL COOLER LINES AND LOOK AT THE TORQUE AREA WHILE ENGINE RUNNING YOU WILL SEE FLUID POURING WHILE ENGINE RUNNING THE OIL PUMP PRESSURE WILL PUSH FLUID OUT AT THE LEAKING AREAS.
Aug 01, 2011 | 1991 Nissan Stanza
While using my Craftmas 17,5 hp lawn tractor with a snowblower attachment, the hydrostatic drive seems to loose power, especially when it working hard and after its been in use for a while. I don't think...
My name is Dane and I'm going to help you with your problem. First, I believe those craftsman units are sealed and there's no way to actually check the hydrostatic oil level. So the first thing to do is make sure that you don'thave any leaks around the transmission assembly. If it looks clean and oil free, I would venture to say that it is more of a 90% chance that your drive belt is the problem, however it isn't from icing up, but rather from the heat of the extra work from the weight of the snowblower, causing it to slip. The belt isn't all that expensive and before I would get excited and start worrying about transmission failure, I would just replace the belt first, and rule it out. Make sure all your pulleys and tensioners don't have any loose hardware, and look alligned.
I think you'll fix the problem though just by the belt replacement. I hope I've helped. Thank you! Dane
Dec 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
715 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
