Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working
I usually put my glass and press the lever and water comes out. One morning I wanted drink water I did exactly that and nothing came down. I checked the water supply and there is water, there was also no leak thank god. So I turned the ICE maker to make ICE. The surprize was it works just fine. The only problem is the water. When I press the lever It sounds like it is going to work but nothig comes down.
  • 5 more comments
  • Anonymous Nov 21, 2007
    In my case similar problem. Looks like the pump is trying to dispense water, but nothing coming out in water line.
  • pburris Nov 24, 2007
    I have had this problem continually. I have taken everything out of my refrig/freezer, turned it off for two days and then the water line unfreezes and water begins to run again. I turn my freezer portion down to 1, and it still happens. I won't buy GE again if this continues.
  • bestmom Nov 26, 2007
    water dispenses very slowly, haven't really tried to solve could it be the filter?
  • Anonymous Nov 30, 2007
    My GE did this for the first time yesterday. Water does come out at the bottom. So I am guessing it must have froze up somewhere in the door also.
  • rialeslj Dec 04, 2007
    I have the same problem with what looks like a frozen water line in the freezer door. Would you email me the GE heater fix PDF?
  • shrife Dec 05, 2007
    here is my email for the pdf file thanks
  • joshlcars2 Jan 30, 2009
    Water is not coming out, frozen in door.
  • 18 Answers
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
My water hose froze between three and five inches inside the freezer door from the filler tap. I ran a piece of weed eater string into the tap and that was as far as it would go. Next I ran a weedeater string up from the bottom quick disconnect under the freezer door until I hit ice in the hose. I could tell I only had a small section frozen. I never turned the unit off. I just used a hair dryer on the filler tap for about thirty minutes. I would stop and check the weed eater string distance into the filler tap and each time it went in a little farther until the ice was gone. I feel the freezup was caused by the ice maker dispenser door staying open when a piece of ice got caught in it. Since then I always check to make sure the dispenser door claose. I have owned this unit for over two years and this my first problem.
Posted on Nov 26, 2007
  • 447 Answers
Sounds to me like the tube is freezing inside the freezer door. Ive had a few do this to me and that was the issue. Disconnect the tube that is behind the toe grill that goes up through the freezer door hinge. Water should come out of the line now that it is disconnected. If water still doent come out than its something else.
Posted on Nov 19, 2007
  • 1 more comment
  • joey  shearer
    joey shearer Nov 25, 2007
    Ive contacted GE to see why this is happening. You guys may need to contact them yourselves and get new freezer doors.
  • joey  shearer
    joey shearer Dec 02, 2007
    Ok guys i contacted GE and they have a heater kit available that will resolve the freezing issue i can email you the service bulletin in PDF format if anyone provides their email and you can see if its something anyone wants to attempt
  • joey  shearer
    joey shearer Dec 12, 2007
    My email is for more info.
Whirlpool side-by-side fridge water dispenser stopped working this morning. When I depress the lever, I can hear it buzzing, but no water comes out.
Have you checked the water pipe is actually producing water
- Not kinked
- Vale turned on at wall
If you are still making ICE... your drinking VALVE is defective.
Without a model number we can speculate no further.
Carnac the Magnificent
Apr 26, 2017 | Whirlpool Refrigerators
The rinse aid dispenser is not adding any rinse aid. how do I unclog it so my drinking glasses don't come out feeling like they have sand all over them.
Good Morning friend, thank you for your post!
I see that you are having an issue with your rinse aid dispenser not adding rinse aid into your Frigidaire dishwasher. You may need to run hot water into your dispenser to help clear out any dirt or clogs within your dispenser. If that does not help I would recommend making sure the water temperature inside your dishwasher is at 120 degrees. If the water is not at the correct temperature it will not allow proper dispensing of the rinse aid. You may also want to check the filter at the bottom of your dishwasher to assure that it has been cleaned out and is not distributing dirt or debris inside of your dishwasher. I would also recommend checking the spray arms to make sure they are not dirty and spray water evenly. You can clean them out using a pipe cleaner. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Frigidaire Dishwashers
What would cause both the water and ice dispenser to stop working?
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at with your name, phone number, address and the model and serial number for your refrigerator.
Apr 07, 2017 | Whirlpool Gold GI5FVAXVB 25 Bottom Mount...
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Kitchen Aid KSCS23FVMK less than a week old had the waterline installed two days ago. Everything was working well (except it seemed that the ice took forever to be made) until this morning when no water...
Slow water and ice, could mean that you haven't gotten all the air out of your system yet. I would suggest holding the lever down for water for quite some time to evacuate the air out. If I am right eventually water will start flowing.
Jul 01, 2011 | Refrigerators
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Our fridge is a little over 6 years old and everything has worked fine until now. Earlier in the day I was able to fill up a glass of water no problem but now no water is coming out of the dispenser. The...
Usually that is from the water line freezing up. Behind your refrigerator drawers there is either a plastic tank or a coil of plastic tube........That is where the water runs so your dispenser puts out chilled water. If your fridge gets too cold that will form ice inside and stop the water from flowing. You can defrost it with a hair dryer or just let the fridge sit open for a few hours. Another thing could be the water valve. When you press the water lever on the dispenser do you hear a noise? Kind of a humming noise. Well, that is your water valve, so if you hear it then it is probably working.
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Drinks depencer not working
check the dispenser lever switch
May 02, 2009 | Refrigerators
Water dispenser will come on at random times
are you talking about the lever where you put your glass to get water or the ice compartment if it where you put your glass to get water it could be that if the pressure is not strong enough to close the valve after you have taken a glass of water or a defective solenoid vavle thanks from gilles
Jan 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
361 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
