Question about Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range
E1 F5 came out and door is locked
Cleaned the oven and when finished the E1 F5 came out and the oven door is locked
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^RF
Posted on Oct 01, 2010
  • tracey417 Nov 20, 2010
    What do you do after you hit the bake button and the code appears? Do you unplug the stove?
    Or does hitting the bake button and getting E0- F2 to come up just fix it?
    Thank You
My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
E1 f5 code oven - YouTube
? 1:51
https://www.youtube.com/watch?v=5F1vwVpmG9U
Dec 28, 2014 - Uploaded by Jay Dornbos
Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
Nov 23, 2016 | Whirlpool Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
Dec 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door locked E1 F5
hi..
The manual says F5 means "failed circuit in control". This means that the control panel is burned out.. So just replace this..
Thank u
rate me!!
Jul 25, 2009 | Kenmore Ovens
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range Logo
258 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
