Question about HP Internet 3-Button Optical Scroll Mouse - PS/2 (P816)
My internet button stopped working
I have an HP and the switch that turns the wireless on or off just stoped working do you know a solution to my problem
0 characters
1 Points
Why isn't my left button working?
Look in the battery compartment and there is often a screw under the battery 5a7c0c41-1fa3-419e-b706-f20ebbf12465.gif this is how I opened up my wireless mouse when mine broke...
May 31, 2014 | Universal Bondidea N86 2.4GHz 1000 /...
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
Oct 12, 2012 | Keyboards & Mice
My hp wireless mouse has stopped working
turn the mouse over, press and hold the tiny button on the bottom. At the same time - find the transmitter connected to your pc and press and hold the tiny button on it too and hold both buttons down for a few seconds. This will calibrate your mouse and return it to working order.
Oct 09, 2011 | HP Wireless Optical Mouse
My H P wireless mouse blue light light is flashing and wont move the cusor it just stoped
a flashing light , if located on the top of a wireless mouse indicates that the battery is low and needs replaced. the other possability may be it lost its connection with the usb fob and you need to press the connect button located on the bottom of the device.
Nov 29, 2010 | HP Wireless Optical Mouse
My HP wireless mouse all of a sudden stopped working (usb connection to my laptop.) I did change the batterie. Do you have any idea what is going on?
Try to completely shutdown your computer when you connect it and turn your laptop back on once the pc is already booted back up switch on the mouse...
Mar 19, 2010 | HP Wireless Optical Mouse
Trying to add the Dynex wireless remote to my HP Notebook
Right below the scroll button there is an eject button. Push this and slide out the cover. You will find the battery compartment. Insert 2, AAA batteries. Be careful about the polarity. It is marked. Just match the polarity. In between the 2 batteries you will find the receiver unit. Slide this one out. Insert this receiver unit into the USB port of your laptop. Close the battery compartment cover. Turn the mouse upside down. You will find an on/off (on the right side top) switch. switch it to on position. If the mouse is not detected, press the connect button below the on/off switch. Good luck.
Feb 08, 2010 | Dynex Wireless Optical Laptop Mouse...
Hot keys have stopped working
Hello look for a button on your keyboard called FKey - press this button and then try again, see if it works... if not hit Fkey again and try again.
Sounds like your function button may be on
May 27, 2009 | Microsoft Wireless Optical Desktop 1000...
I have the Microsoft wireless laser mouse 5000 and it just stoped working on me i was working fine than it just stoped
Make sure that the batteries are good and try pressing the receiver button and then on the bottom of the keyboard press the small button that re-sets and connects the keyboard to the receiver. It then should work properly. Hope this helps. Bud
Jan 07, 2009 | Microsoft Wireless Laser Mouse 5000
Open Questions:
See all HP Internet 3-Button Optical Scroll Mouse - PS/2 Questions
HP Internet 3-Button Optical Scroll Mouse - PS/2 (P816) Logo
150 people viewed this question
Top HP Keyboards & Mice Experts
Brian Sullivan
Brian Sullivan
Are you a HP Keyboard and Mice Expert? Answer questions, earn points and help others
