Tv keys locked
Can't turn on tv to program any remote what the trick please help asap
    Sergeant:
  • 269 Answers
What brand?
Posted on Aug 01, 2009
How do I program this remote start . I just got this for a replacment one and It never came with the instuctions Please help me?
Instructions
    • 1 Climb into your Jeep Grand Cherokee with your keyless remote(s) in hand and your manual ignition key. Do not close the driver's door.
    • 2 Hit the "Lock" switch on your driver's side door and insert the key into the ignition.
    • 3 Turn the key to the "Run" position and aim the keyless remote at the steering wheel. Press and hold the "Lock" button for five seconds.
    • 4 Wait for the locks to respond by cycling then program each successive remote (up to four total) by holding the lock until the locks respond. Each remote must be programmed within 20 seconds of the last.
    • 5 Turn the key in the ignition back to the "Off" position then quickly back to the "Run" position within 20 seconds of programming your last remote.
    • 6 Turn the car off and remove the key from the ignition to complete the programming sequence.
hope this helps
Jan 19, 2015 | 2000 Jeep Grand Cherokee Limited
I lost the instructions for operating my 3300 one for all remote control. Please help me program my Toshiba tv so I'll be able to operate my tv set.
Turn on your Toshiba TV. On your remote, press the TV key. Press and hold the SET key depressed until the red LED blinks twice, then release it. Press the 0, 1, 5, and 4 keys. Point your remote at the TV and press the POWER key. Your TV should turn off. If not, repeat the programming routine pressing the 0156, 0060, or 1256 keys
Oct 03, 2013 | One For All URC-3300 Remote Control
I want to unlock the child lock key on my LCD TV
Since this set like all others with the "child lock" require a code to be entered and the remote is what is used, I would say it cannot be done without the correct remote and the password.
Dec 05, 2012 | Televison & Video
I need help I just won a tv but it didnt come with a remote but I have a RCA remote transmitter. Im trying to program it for the tv but I dont have the book anymore can you please help me The tv is on but...
This Web page should allow you to find the codes for any devices you want to add for this remote.http://remotefinder.rca.com/default.aspx?site=rca
Other than that there is an easy way to program this remote.
1. Turn on the device by hand. 2. Hold down the device name key.(hold the TV button to program a TV) 3. While holding down this key also hold down the power key until the red light turns off and comes back on. Then release both buttons. 4. From here hit the power button repeatedly until the device turns off. 5. Hit the stop key at the bottom. Now the remote is programmed for that device.
May 05, 2011 | Televison & Video
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
T.v. WE BOUGHT IS ON CHILD LOCK....
Maybe this will help you overcome those pesky child locks
Philips and Magnavox:
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Good luck and let us know how this turns out for you.
Please rate my help++++Thanks for using FIXYA
May 06, 2010 | Jensen TS2750J TV
Reprogram keyless entry
It took me a few attempts to program a new keyless remote for my 2002 Chevy Blazer.
Insert key into ignition but don' turn it yet. While holding down the UNLOCK switch on the door, the trick is to cycle the ignition ON OFF ON OFF as quickly as possible then release the UNLOCK switch. If done correctly the door locks will cycle 1x to acknowledge. Then hold both the unlock and lock buttons down on the remote for about 15 seconds. The locks should cycle again to confirm...Hope this helps.
Mar 19, 2009 | 2002 Chevrolet Blazer
Disney 13' Princess tv
You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Hope this helps
Jan 16, 2009 | Disney 13" TV
TV -Ferguson (Wide Screen) model no: W7023U. unable to operate either with remote control or manually.
Is it possible it has locked itself? It can be locked in 3 ways according to manual.
1. by pressing the remote's stand by key for more than 3 secs.
2. By programming an auto stop.
3. By putting it on stand by after programming a wake-up time.
Flashing "red on" indicates it is locked. It can only be turned on by the remote. Press any number key on the remote to unlock it.
Aug 16, 2008 | Televison & Video
Cannot program universal remote control rca RCR3273
When you find out how to do it tell me. I have the same problem trying to find the code for a Magnavox 15"LCD TV. The codes listed are not doing the trick.
Jul 15, 2008 | RCA Universal Remote Control
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
