Question about Goldstar Heating & Cooling
Goldstar ga-0510ac How do I remove the filter. It appears to be in the bottom but I can't pull it out.
Model GA-1215LC
I want to replace this air conditioningunit GoldStar GA-1215C for a heat/air conditioning unit. Any recommendations?
Jul 09, 2012 | Goldstar Heating & Cooling
Does this model have a washable filter and where would it be so I can remove it and clean it. Pat
Yes, it has a washable filter. To access it, remove the water collection bucket and look up just inside the bucket holder. There you should see a tab type handle. That's the frame for the filter. Pull it down and out. Wsh it with warm water and liquid dish washing detergent. Rinse and dry thoroughly, before reinstalling it. DO NOT operate the unit without the filter.
Hope this helped you. Please let me know. Thanks.
Jun 26, 2011 | Goldstar DH304 Dehumidifier
My Goldstar dehumidifer won't do anything. I'm trying to take the back grill off so I can clean filter, blades and whatever. I've removed every screw on the thing and can't the back to...
tia0418 - I'm sorry you're having such a problem with this. But, taking off the back, won't allow you access to the air intake filter. It's behind the louvers on the front of the unit.
You failed to mention which model Goldstar Dehumidifier you have, but most have the same features. If you remove the bucket and look up in the cavity where the bucket was removed, you should see what looks like a plastic pull handle. That's the handle for the filter frame. Pull that down and the filter and frame will come out. You then can clean the filter, by following the Owner's Manual Instructions.
The clamps that you referred to are just spring type clamps in a "V" shape. Push the top of the "V" together and the back should release from the cabinet. You can "carefully" use a flat bladed screw driver to do this, if necessary.
Hope this helped you further troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Goldstar Dehumidifiers
I don't have the manual and need to replace and/or clean the air filter on my Goldstar DH304. Where do I find it on the appliance?
if this is the correct picture - pull out the collection bucket and reach just inside the opening at the top (just at the bottom of the grill in the front) the filter is plastic and pulls straight down. Clean it tin soapy water, dry it, and slide it back it place.
Oct 10, 2010 | Goldstar DH304 Dehumidifier
Where is the filter
It's behind the front grill underneath the vent. Some window A/C you can slide the filter out from the side or the bottom. Some you have to pull the whole front cover out. Some is part of the front grill and is not removable, and can be cleaned out instead of replacing.
Jul 09, 2010 | Goldstar R5050 Air Conditioner
Do i need to change a filter?
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=291198
here is the air filter replacement (or just pull out and clean your self
here is the breakdown for all parts for your unit
i didnt see another filter unless you see one in the back
hope this helps
Apr 05, 2010 | Goldstar DH304 Dehumidifier
I want to clean filter
remove water bucket from cabinet. filter is above,pull down fitter will come out wash with soft brush and warm soapy water slide filter back in groove above. waa laa.....!
Nov 30, 2009 | Goldstar Dehumidifiers
It runs all the time.. does it have a filter I have to replace or clean and if so where is it?
Can help with the filter location, remove the front water catch basin and look up under front of unit it should have a filter that pulls down from front.
Oct 27, 2009 | Goldstar DH304 Dehumidifier
How to clean the filter
The filter is behind the front grill. Pop off the grill, should just pop off, pull down from the top under the vents. the filter is behind there.
Sep 18, 2009 | Goldstar KG6000R Window Air Conditioner
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Heating & Cooling Logo
67 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
