Question about RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer
Craftsman framing gun shoots every other nail how cam i fix it?
The nail gun was left in my house when i moved in. seems to be good shape other than it shoots every other nail. i tried oiling it but it didnt make a difference.
  • 142 Answers
Make sure the track is clean and lubricated, also spray we40 in the nose
Posted on Jul 20, 2009
Nailer wont advance the nails then it shoots blank
Try ez test to check for proper operation. Remove nails and air supply, point nose of gun up then down again. The driver should not move from the top of cylinder position. If driver is moving up then down replace the driver oring. If driver oring seems ok then connect air supply and bump fire the nailer without nails against soft wood and door open so that you can see the driver and feeder moving. Bump fire the gun and make sure that the driver is moving all the way back up to top of cylinder and the feeder is moving rapidly back and forward. If movement seems ok then hold the nose down on soft wood and depress and hold the trigger. This will fire the gun but driver will stay at the bottom position and not return until you release the trigger or lift the gun. When holding the gun with the driver down position, no air should leak out the top or bottom of the gun. If air leaks out bottom, replace lower bumper, if air leaks out the top replace the upper bumper. Good luck
Mar 19, 2015 | Porter Cable Coil Roofing Nailer
My airace framing air nail gun blows air when i try to shoot it
Look for an O ring kit,,many times the firing cap seal splits thus loss of air
Mar 30, 2013 | Air Tools & Compressors
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
Hitachi nr83aa shoots out nail and it bends last inch of nail over
One problem may be your air pressure at the gun. It should be between 90 and 100 psi to fully drive the nail fast enough to prevent nails being left high in the work or bent over. Bent nails can also happen if you are driving nails into very hardwood or hit a knot in softer woods but not usually with framing nailers. Another thing to look for is a rounded off driver that is slipping off the head of the nail before it is fully driven into the work. The tip of the driver should be round (some have a crescent moon shape) but square to the sides. If you need a new driver the part number is 878-630, shop the web for one of these, they run beteween $80 and $100 plus shipping.
Jan 02, 2012 | Air Tools & Compressors
Hello i have a mildly used FR350 round head framing nailer. the problem is that it will shoot two or three nails then jam up? thanks todd
This gun is very reliable unless tip is broken or miss-shaped and or wrong nails are being used. Depending on model # could be clip head or full round. For best results do not use generic nails because they are not the exact angle required. Place a strip of nails on outside of rails with nail-heads aligned with edge of rails. The first nail should align with path of the driver (place a straight edge alighed with path of driver). Most generic nails do not align correctly. Good luck
Feb 28, 2011 | Porter Cable Air Tools & Compressors
I have a FC350A FRAMING NAILER, IT IS IN THE
check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Feb 02, 2010 | Air Tools & Compressors
My dewalt framing gun will not shoot out nails
several things could cause this need more info..... be sure your
firing correct nails #1, check air pressure #2,make sure spring clip
is pushing nails forward #3, make sure ram is moving in the head #4
if this does not help we can go deeper.... good luck
Nov 01, 2009 | Dewalt Air Tools & Compressors
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
216 people viewed this question
Top RTO Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
