Display on my Brivis LCD panel is missing half the text.
I noticed on my LCD display that the text that appears on the panel does not appear correctly. Basically the top half of all words, numbers etc. have been chopped. The heater appears to be working ok, but not sure if there is an underlying issue.
    Sniper:
  • 81 Answers
There could be a problem with the LCD display or the PCB of the control. If it doesn't bother you, I wouldn't have it fixed, but if it does I would. Generally the text/numbers displays the time and the room and set temperatures. It also shows messages about the heater. i.e. "Pre heating heater furnace - Please wait!" This display is not really important.
Mat
Posted on Jul 20, 2009
Half Screen
It is either the lcd panel OR the video card / motherboard or it could just be a completly bad driver.
If you turn it on and hit f2 or f8 does it appear in this screens?
If not, it is a bad driver.
If a bad driver, turn on hit f8, choose low video resolution mode, surf to your manufacturers website, download, install and reboot.
Try display to an external monitor, if the line appears on the external monitor, the issue is a bad video card.
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
If the issue does NOT appear on the external monitor, the issue is the lcd panel.
May 02, 2013 | Acer Iconia Tab A50010S32u Notebook
Half screen is blurred
if as it appears a LCD and problem is half screen is "blurred" the set uses two (or one large) boards and each drives the picture on half the screen---could be one bad, poor connection or worst case defect in screen unit (display panel) which would be fatal.
Aug 27, 2012 | Toshiba Regza 52XF550U 52 in. LCD HDTV
When I hook up my sanyo DP 19649 to my PC I can't get a picture, what do I need to do , am I missing something?
Windows 7
Go to the control panel and select "appearance and personalization"
Under display select "connect to an external display"
Windows XP
It can be found in control panel>Display.
Mar 20, 2011 | Sanyo DP19649 LCD TV
Ssss
Trying to run too many programs at the same time can cause display problems such as jittery or choppy video. If you notice erratic or reduced visual performance on your computer, try one or more of the actions described below.
1.The more programs you have open, the more system resources Windows needs. Try closing programs that you're not currently using, or reducing the window size.
2.Even if you have only a few programs running, some programs (such as video-editing programs) and features (such as high-definition television) use a lot of system resources. Running too many of these programs at the same time puts a strain on system resources and might degrade display quality or make video appear jittery or disconnected.
On some computers, very high resolution require a lot of system resources to display properly. If you notice problems at high resolutions, try lowering the resolution until the problems disappear.
1 open display from control panel
  1. In the left pane, click Adjust resolution.
  2. In the Resolution list, click the resolution you want, and then click Apply.
If you set the DPI higher than 96, and you're running the Aero desktop experience, the text and other items on the screen might appear blurry in some programs that aren't designed for high-DPI display. To avoid this problem, follow these steps:
To make text and on-screen items clearer in programs that aren't designed for high DPIIf you set the,
  1. In the left pane, click Set custom text size (DPI). ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. In the Custom DPI Setting dialog box, select the Use Windows XP style DPI scaling check box, and then click OK.
Dec 11, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
Text on display does not show
You need a new LCD panel (complete). Unfortunately Xerox will charge you £350 including a visit from an Engineer, or you can buy one yourself and instal it. Cost $121 from USA http://www.sparepartswarehouse.com/Xerox,Printer,Part,802K93650.aspx
Jun 29, 2009 | Xerox Phaser 8560MFP Laser Printer
Only half of sreen lights up and is frozen. Do all 350 have a memory card? When my husband brought it in from his last trip, there appears to be no memory card in it. Could this be my problem with only...
Stock Nuvi's from the factory do not include a memory card (SD card). You do not need a memory card to operate the Nuvi. The memory card is only needed if you want to add more storage space for music or pictures or if you want to add additional maps. It has nothing to do with the LCD display. Having worked on these units for quite sometime, anytime you have 1/2 of the screen missing, it tells me that your LCD display is defective.
- Jim
SHARCNET-USA
Dec 03, 2008 | Garmin nuvi 350 GPS Receiver
GatewayMX6453
-Try connecting External monitor, If the display appear the same you have some hardware issue ,common issue video card.
-If the display appear to be ok, It appears that you have LCD issue.-
-Try reseating the lcd cable or contact manufacturer to replace the lcd assembly.
Oct 10, 2008 | Gateway MX6453 Notebook
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Heating & Cooling Logo
367 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
