Question about Samsung SCX 4521F All-In-One Laser Printer
Am connected Samsung scx 4521f all in one printer via LPT cable . it does not show sacnner. printing is ok and my printer USB is not working.
How to enable scanner via LPT port.
5 Suggested Answers
SOURCE:
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
Posted on Oct 20, 2008
  • 22 Answers
SOURCE: SCX 4521F scanner driver will not configure. Have
The problem is the firewall of your computer because its blocking the scanner to work better. Check the firewall of your computer from it is control panel if its on. If it is on, click the exception tab then check the network scanner tool and scan to pc box. Just put acheck on all scan or scanner word.
Posted on Jul 28, 2009
  • 526 Answers
SOURCE: hi,my printer/scanner scx-4200 will not scann
Wireless scanning is not a supported feature in the SCX-4200.
Thanks adi
Posted on Jan 10, 2010
  • 360 Answers
SOURCE: my driver for samsung scx4521f is installed and prints but the scanner does not work
hello friend
in samsung driver cd their have a software SMARTRU that is the driver for scaning function so you have to install this driver.if u didnt found it
go the www.samsungusa.com and download it.
Posted on Jan 29, 2012
Problem install scanner epson gt-12000 on lpt port
You might need to go into your bios and configure your parallel port as epp or ecp for bidirectional communication.
Mar 25, 2011 | Epson GT 12000 Flatbed Scanner
Turn on enable bidirectional
  1. In Control Panel, click Printers.
  2. Right-click the bidirectional printer, and then click Properties.
  3. Click the Ports tab, click Enable bidirectional support, and then click OK.
    Also if parallel port, this is also set in BIOS, under LPT port settings.
May 17, 2010 | Canon i9100 InkJet Photo Printer
Intel lpt not working
Enter Bios by pressing F2 during boot up Advanced options,Make sure EPP is chosen for that port and it is enabled epp stands for enhanced paralell printing..
Aug 13, 2009 | Computers & Internet
Installed the scanner program for bjc-80 onto a Netbook with only USB ports...wont recognize printer/scanner,,,help
Netbooks usually doesn't have PCMCIA capability. what you sould do is to disable the bidirectional function of the printer. To disable the bidirectional support You have to open the printers properties. In the "printers and faxes" map, right click on the printer and choose properties. then on the "Ports" tab, down below there is a tick mark choice with some text like: "Enable bi-directional support " you have to clear the tick mark!
Apr 25, 2009 | Canon BJC 80 InkJet Printer
Can a scanner be attached via usb port to a xe-a41s cash register
A lot of times with Sharp products, the capability can be there but the software might have to be enabled to do it.
contact www.sharp-usa.com to find out if that do able on that particular model.
Nov 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
How to assign ip to the printer
Using the LPT port is not the same as using the network port. The LPT port does not utulise an IP address.
Plug in a network cable to network port and the printer wil usually aquire an ip address via DHCP.
I repeat the LPT port is not a network port and cant initialise an ip address
May 23, 2008 | Brother HL 5250DN Laser Printer
Scanner on ir2016i
for printer it s lpt port....
Feb 05, 2008 | Office Equipment & Supplies
Samsung SCX 4521F All-In-One Laser Printer Logo
245 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
