Question about Akai LCT2662 Television
AKAI tv will not power on
My tv will not power on. plugged into outlet but do not get a green light.
  • 5 more comments
  • Anonymous Nov 25, 2007
    no power ONLY red light keeps flashing added new batteries to remote
  • Ernest Smithling Dec 28, 2007
    After a power outage my Akai 46 inch DLP HD will not come on at all.  No picture, no sound,no noise, no light in front of the tv.  I unplugged it and then plugged it back in about an hour later and still nothing.
  • sferreir May 12, 2008
    no power at all
  • Anonymous Jun 10, 2008
    my akai lct2662 is getting no power at all
  • Anonymous Jul 05, 2008
    Plugged it in and it does not come on..... and no lights of any kind....
    What could be the problem???
  • dmdickson Nov 02, 2008
    Same problem - no front lights and will not turn on. I tried the on/off several times and did get a flash of a picture.
    My Sam's Club bargain wasn't much of one this time.
  • JALIMEX777 Jan 01, 2009
    I GOT A GOOD DEAL ON THIS LCT2662 CAUSE IT WILL NOT TURN ON ... THINKING THAT MAYBE A FUSE WILL BE BLOW .. BUT TO MY SURPRISE THERE WAS NO FUSE.. LIKE THE OLD TV .... SO NOW WHAT DO I DO ...CAN SOME ONE HELP PLEASE ...
  • 62 Answers
Call 800-726-4005
Posted on Mar 29, 2008
4 Suggested Answers
  • 62 Answers
SOURCE: Akai LCT2060 - Won't turn on
Call 800-726-4405 to see if they have an adapter and power cord - if they do not - have them email their corp office for the part.
Russmann
  • 203 Answers
SOURCE: Akai lcd Television
Sounds like the inverter board. That is the board that powers the screen. When you take the back off, it is the one with several little transformers on it. Also, it usually has a metal cover over it. Get the part number off of it and search online for the best price, or if that seems like too much work, take it to a shop where they do the factory service. Not an independent, local servicecenter. Trust me on this one. Good luck, Russmann.
Posted on Aug 21, 2008
tlm931
  • 273 Answers
SOURCE: Television will not turn on with remote or from
there are capacitors on the power supply that will be vented or the top bulged out
those will need to be repalced to correct the problem
1000mfd 16volt caps
Posted on Oct 25, 2009
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
AKAI PDP5006H Plasma tv
1) Is the TV plugged directly into an outlet or is it plugged into another device, such as a cable box or audio receiver? If it is, try plugging directly into a wall outlet. Sometimes, devices like cable boxes don't provide enough current to power on more powerful newer TVs (like Plasma, LCD, etc) .
2) Check the manual to see if the flashing LED is a code for something you need to troubleshoot. The number and color of flashes may correspond to a problem that may or may not be easily fixed.
Hope that helps. Let me know how you make out.
Jan 15, 2008 | Akai PDP-5006HRB 50 in. Plasma Television
RED LIGHT FLASHES 10 TIMES BUT WILL NOT TURN ON!
There might really be a problem with the unit. Try unplugging it out of the power outlet and plug it back in after 30 seconds. If your using a power box (voltage regulator), try plugging it directly to the outlet. If all nothing happens, see a local tv tech in your area. The unit could be damaged.
Nov 08, 2009 | Akai PT4298HD Rear Projection Television
Television will not turn on with remote or from the tv itself. The red light is on, so it is getting power and we have tried other plugs, so outlet is not the problem. Akai 32" LCD TV/DVD Player Combo...
1000mfd 16volt caps
Oct 24, 2009 | Akai LCT3201TD 32 in. LCD Television
Akai LCT3285TA Television won't turn on
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
Sep 24, 2009 | Akai LCT3285TA 32 in. LCD Television
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
Aug 30, 2009 | Akai LCT3201TD 32 in. LCD Television
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
Akai LCT2662 Television Logo
167 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
