Question about Konica Minolta bizhub C250 All-In-One Laser Printer
We have a customer that has a KONICA 2125 copier with a F55 code the service manual just says not enough zero cross signals within a specified time period.Can any one help?
  • lee6549 Jul 27, 2009
    We have a customer with a Konica 2125 copier that has a blank LCD screen on the control panel.
    The print switch will glow orange but will not turn green. The AES, RADF, AES lights are on but you cannot make it zoom up or down or make a copy. The LCD screen is always blank even if you open a side door.
    We have switched out the following items from a known working machine and still have the same problem.
    All printed circuit boards in back of machine.
    All wiring harnesses to all boards and AC wiring harnesses as well.
    Complete control panel including both door interlock switches.
    Complete drum/developer unit.
    Complete fuser unit.
    Tested exposure lamp and is OK.
    Checked all grounds in back of machine and all are tight.
    Complete feed section.
    Complete exit section.
    Power cord including noise filter board and circuit breaker.
    I have worked on office equipment for 18 yrs and cannot figure this one out, can anyone help us in this situation.
    Lee Osborne
    828.327.7777
    President:
  • 2,306 Answers
Could have a blown fuse in power supply, zero crossing usually means there is a problem with the power outlet you have it plugged into.
Posted on Jul 20, 2009
  • Craig Gillette
    Craig Gillette Jul 27, 2009
    Years ago I saw a similar problem where the power company had changed a transformer causing the zero crossing signals to be bad, drove us crazy, on even the new circuit boards we had to modify the chip for zero crossing detection to get rid of the AC fail errors.
Error c6400 in 1135
The Error is described in the Service Manual as - "Zero cross signal error The zero cross signal does not reach the control PWB for specified time."
This can be a damaged wire harness between the High Voltage PCB and another board or a defective Power Source PCB. Bad power at the outlet can also cause this.
Move the machine to another location and make sure nothing else is plugged into the same line. If the problem goes away have an electrician check your wiring.
If the problem still occurs have a Service Technician check the machine and replace the bad part.
Feb 27, 2015 | Kyocera FS-1135MFP w/ Document Feeder
C6400
C6400 Zero-crossing signal problem
• The engine PWB does not detect the
zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes: Poor contact in the connector terminals.
Remarks: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Causes: Defective power supply PWB.
Remarks: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Remarks: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Feb 04, 2011 | Kyocera Copystar CS-1820 Black and White...
Kyocera mita 5035 code 6400 c
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Dec 18, 2010 | Kyocera Mita KM-5035 Printer
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB
- Defective the engine/high voltage PWB.
Dec 15, 2010 | Kyocera FS-1016 Printer
I have Kyocera km-2050 it coming error for call for services error code -C6400
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
My kyocera km1820 displays error code c6400
specified below.
At power-on: 3 s
Others: 5 s
Causes:
- Poor contact in the connector terminals.
- Defective power supply PWB.
- Defective engine PWB.
Check procedures/corrective measures:
- Check the connection of connectors YC7
necessary.
- Replace the engine PWB if C6400 is detected
Sep 24, 2010 | Kyocera Copystar CS-1820 Black and White...
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Error c6400
A Copystar or Kyocera service technician must reset the fuser memory.
Jun 29, 2009 | Office Equipment & Supplies
Malfunction detected, please call Tech Rep. C3451
Here's the reset procedure.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
And yes, a power outage could cause this.
Jun 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Keyocera 1820 balck & white copier error code C6400 on start up,
The engine PCB does not detect the
zero-crossing signal for the time specified
below. At power-on: 3 s Others: 5 s
That is what the code means in the service manual. However you can try a reset by doing the following. Press 10871087 to enter maintenance mode. Once in maintenace mode press 906 then follow the steps below
1. Press the start key.
2. Select the EXECUTE using the up/down cursor keys. It is displayed in reverse.
3. Press the start key to reset partial operation control. The maintenance mode is exited, and the machine
returns to the same status as when the power switch is turned on.
If you do not feel comfortable performing this operation, or the problem persists then call a technician immediately.
Jan 26, 2009 | Kyocera Copystar CS-1820 Black and White...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
249 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
