Question about Garden
ES-2100 Blower : Bogging out and won't run to max HP speed
I have changed spark plug and checked the air filter which seems to be clean. Wondering if there is a fuel filter on this machine that could be causing this. If I put my hand over the end to trap air coming out it will speed up to max. Seems like it must be fuel filter and/or air filter but like I said - the air filter is clean.
  • 127 Answers
Change fuel filter in gas tank
Posted on Jul 26, 2009
I have a toro 98 cc powerlite snow blower. did not drain fuel after storing for the summer. drained fuel, put new mixed fuel in and engine wouldn't start. replaced spark plug, cleaned carb and bottom
cleaning the carb was a good thing if done properly. fuel tarnishes over time and this tarnish destroys diaphragms in carbs and also plugs up the jets. If you used compressed air at a high velocity then you may have damaged the internal check valves in the carb. Also check your fuel filter and air filter
Oct 08, 2014 | Garden
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna model 41
Try changing the spark plug. Maybe it is bad and does not have enough spark . You may also want to check if the carburetor is getting gas . It seems that it probably is not . By the fact that you have to spray stating fluid. Check the hoses, filters, and the choke. Remove and clean the fuel filter and air filter . And by all means , check the ignition switch. That it is on and working .
Dec 19, 2011 | Husqvarna Garden
My 05' Drz 125l has ben sitting 4 the last 1-1/2 yrs, i was wondering whats some stuff i should do to maintain it, never really did anything besides cleaning air filter, changing oil n filter, spark...
hiya
first thing is drain the fuel and replace
clean out the carb
inspect the air box and replace filter
new spark plug
check tyre pressure
that should do it
hope this helps
John
Sep 27, 2011 | 2005 Suzuki DR-Z 125 L
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
What does a major tune up for a 2004 chevy impala consist of? What should be done and needs to be done?
New spark plugs, oil and oil filter, transmission flush and fill, fuel filter, air filter, coolant flush and fill, clean throttle body plate and bore, clean the MAF sensor, replace any loose or cracked vacuum lines, PCV valve, new air filter, new battery.
99% of the time all you should ever need for a tune up is new spark plugs, and a clean air filter and throttle body. But since your inquiry indicated "major" I gave it more critical thought.
Feb 18, 2011 | Chevrolet Impala Cars & Trucks
How do I get my lawn mower ready for spring time use?
This is what a "General service" looks like at www.arcolawn.com
  • (Mower 2 cycle GS)
GENERAL SERVICE:
1. SHARPENED & BALANCED BLADE
2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS
3. REPLACED SPARK PLUG
4. FLUSHED FUEL SYSTEM
5. CLEANED CARBURETOR HOUSING
6. LUBED CABLES
7. CHECKED OIL SEALS
8. SERVICED AIR FILTER
9. CLEANED EXHAUST PORTS
10. TESTRAN & ADJUSTED.
  • (Mower 4 cycle gs)
GENERAL SERVICE 1. SHARPENED & BALANCED BLADE 2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS 3. REPLACED SPARK PLUG 4. CHANGED OIL 5. FLUSHED FUEL SYSTEM 6. CLEANED CARBURETOR 7. LUBED CABLES 8. CHECKED OIL SEALS 9. SERVICED AIR FILTER 10. TEST RAN & ADJUSTED.
  • (rider tuneup)
Tune up
1.TIGHTENED ENGINE MOUNTING BOLTS
2. INSPECTED BOTTOMOIL SEAL.
3.TEST GOVERNOR OPERATION & ADJUSTEDRPM'S.
4.CHECK SHAFT BEARING.
5.REMOVED BLOWER HOUSING &CLEANED COOLING SYSTEM.
6. REPLACED SPARK PLUG
7.CHANGED OIL.
8.REPLACED OR CLEANED AIR FILTER.
9.ADJUST FUEL/AIR MIXTURE & SPEED LIMIT SCREWS.
10.REPLACED FUEL FILTERS AS REQUIRED.
11.CHECK FUELLINES, VALVES, & CLAMPS.
12.INSTALL FRESH FUEL IN GASTANK.
13.SHARPEN BLADE(S) & CLEAN UNDER BLADE COVER.
14.CHECK DECK, EXAMINE BELTS, PULLEYS.
15. EXAMINETRANSMISSION/DIFFERENTIAL FLUID LEVELS,
16.CHECKGREASE FITTINGS, WHEELS, WHEEL BEARINGS, HEIGHTADJUSTER.
17. CHECK CABLES & CONTROLS ADJUST BRAKE &CLUTCH.
18. CHARGE & TEST BATTERY. (IF EQUIPPED).
19. TESTSAFETY SYSTEMS.
20.REMOVED CYLINDER HEAD & CHECKEDCYLINDER FOR WEAR/DAMAGE. CHECKED ROD BEARINGPLAY. 21.CHECKED VALVES FOR PITTING, WARPING, CARBONBUILDUP & SEATING.
22.CHECKED VALVE STEM CLEARANCESFOR EXCESSIVE WEAR.
23.CLEANED CARBON BUILDUP FROMCOMBUSTION CHAMBER.
24.MACHINED HEAD FLAT.
25.CHECKEDTIMING KEY FOR DAMAGE.
26.CLEANED OR REPLACED POINTSAND CONDENSER (AS NEEDED).
27. SET TIMING. ADJUSTEDMAGNETO AIR GAP.
28.CHECKED THROTTLE SHAFT FOREXCESSIVE WEAR & REPLACED IF NEEDED.
29.DISASSEMBLED& CLEANED CARBURETOR. REPLACED DIAPHRAGM, NEEDLE &SEAT, NEEDLE VALVES ETC. AS NEEDED.(see carburetor section)
I hope this helps! get parts for the service at a dealer like www.arcolawn.com
Feb 14, 2011 | Garden
I have a 2000 chevy s 10 with 152,000 miles on it what does a tune up consist of
I would change the spark plugs, spark plug wires, distributor cap and rotor, fuel filter, check and change air filter if dirty, check timing, check and top off all fluids, check or change transmission fluid, check brake pads/.shoes and drums/rotors for wear and check tire pressure, check the condition of all belts and hoses and replace as needed, check condition of radiator antifreeze and top off or replace as needed.
Jun 10, 2010 | 2000 Chevrolet S-10
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
My car doesnt accelerate like its supposed to do.It seems to me like it boags down when i push the gas but when i let off the gas a little it will accelerate slowly.It has no power, once you get to going...
try to have your intake manifold and air filter cleaned. Also, try to replace the fuel filter. these are usually the culprits for the problem that you are experiencing.
May 14, 2009 | 1995 Honda Accord
Garden Logo
356 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
